Hey guys as no one has started a thread yet I propose nandos at buranda for dinner. Same thing as before just let me know if you arte comming so i can make the necessary bookings
Details for new people
Nando's Buranda
(opposite PA Hospital)
Time:
7pm
What to bring:
Money for your meal and mates if they are interested.
Cheers
Mushroom
https://www.sau.com.au/forums/topic/159977-tuesday-night-dinner-13th/
Nandos is OK by me. My restaurant isn't available on Tuesday nights and is booked out already for tomorrow night. Will be looking at Rasa Ria for a couple of weeks time for someone's birthday. Will be on a Wednesday night though as they don't open on Tuesdays.
Count me in for dinner.
Headcount as I see it.
01. Mushroom
02. SMR33
03. Revhead
04. Rhinorebel
05. Oblivion (not confirmed)
06. Ad_N (not confirmed)
07. Einstein (not confirmed)
08. FineLine (not confirmed)
09. Fineline's guest (not confirmed)
10. Ivonin (not confirmed)
11. mrbenno
12. Andy
13. Anna
01. Mushroom
02. SMR33
03. Revhead
04. Rhinorebel
08. FineLine
11. mrbenno
12. Andy
13. Anna
14. Spilmer
Any more?
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
