well drag warz has been run and won.
theo took out sport rwd, finally some final action for him, and some low nines as well which if i am correct he backed up and should have lowered the et record and also the MPH record.
was great to see team berzerky out there with a good 5 or 6 car team in the class, all there guys did really well. i must also say publicly thankyou to you guys for your sportsmanship in the semi when you realised i had an issue getting the cressida to crank over. its great to see, its a shame others in the sport arent like it.
we were really happy with our performance on the day even with a slipping auto we still ran a pb of 10.008 et at 139.99 mph and on another pass went 143.32 mph. once the box is sorted at its current level of tune i am confident of a 9.8 et. then we will progressively wind the boost into it and see what it can do.
i didnt get to see mark run but his car sounded strong all day long.
cheers
shane
https://www.sau.com.au/forums/topic/159982-drag-warz/
Not much of a crowd at all. Not very well publicised but we still had fun. Had a good day even though we broke the car :)
Was great to catch up with a bunch of guys I only ever see at Sport Compact events esp the Cressida guys. Big thank you to the Bezerkly Automotive team who had more cars there than just about any other shop and managed a couple of runner-up positions for the first timers!
Awesome stuff!
https://www.sau.com.au/forums/topic/159982-drag-warz/#findComment-2970545
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
