Item: N13 Ca18det Pulsar
Website:
Item Condition: Interior excellent, paint pretty good
Reason for Selling: Financial reasons
Price and Payment Conditions: $6000 or swap
Extra Info: CHEAP AS CHIPS $6000 thats 6000 O.n.O
CA18det converted
T28 turbo
External coils
Forged motor
Microtech mt8 with hand controller
Fmic
3" exhaust
Walbro pump
Fuel reg
New wastegate actuator and bracket
Bosch external coils with 9mm leads
Adjustable cam gears
New Exeedy Clutch
New GearBox
New Drive Shafts
Cleaned and Tested Injectors
Custom green respray
Full bodykit
17inch chrome rims, near new tyres
lowered springs
Full interior retrimed in white and green including boot
Custom boot install
Screen with Ps2
Green neons throughout
The whole car has basically been modified, not much left is stock, Interior is in excellent condition with no rips. Paint is Good condition, little bit of rust coming through around the hatch, couple of paint chips here and there, front bar is cracked. Excellent head turner. With alot of get up and go.
237Hp at 13Psi
Rwc can be arranged!
Contact Details: Matt 0407651529 or Pm
https://www.sau.com.au/forums/topic/159983-custom-n13-pulsar/
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
