How can i improve my 1/4 time
Guest KILLER-T
Hi i am looking to better my 1/4 mile times the last time i took my car to the drags i ran a best time of 13.9 which i wasnt to happy with.I was thinking i should atleast be in the 13.5's with 244rwhp but it was not going to happen i think that maybe i should go for a set of softer shockies on the back because the ones on the back are rock hard would this make a differance to my times or is 13.9 abut right for my power output :?
https://www.sau.com.au/forums/topic/16-how-can-i-improve-my-14-time/
Definately take your car to a suspension specialist and ask them to set it up for 1/4 mile runs ie. non-lateral driving style. Suspension plays a bigger part in performance than most people give it credit for.
I don't want to sound like I'm bragging but this is a good example. My car blew off more powerful cars due to it's suspension setup, around the track and 0-100. This was on Serious Performance #5. I couldn't believe it myself to be honest.
Guest KILLER-T
I had a look at some adjustable shocks for the back today it looks like it will be about $1000 a cnr to fit which is a bit more than i can spend rite now since i need to pay a few things before i can do any more to my car i was told that i should also get a camber adjustment kit for my car because the car has been droped a bit and the rear wheels need a bit of adjustment and to also get rid of the khumos of the back they r 255 40 17's so it will be another $1000 for a good set of rear tyres damm i need more monie or a second job :oops:
  • 2 years later...
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
