As the title says I'm considering selling my R33,
The car makes a reliable 360rwkw on 24psi however I generally don't run anymore than 20psi (300rwkw roughly).
I'm thinking along the lines of 19k give or take
Details as follow:
- 1994 S1 R33
- Rb25det fully balanced
- GTR Rods & ARP rod bolts
- ACL Forged pistons
- Standard Nissan Head gasket
- Performance Springs valve springs
- CPC Custom plenum & 80mm throttle body
- Stainless top mount manifold
- GT3540 & Tial 38mm gate with braided lines
- 3.5" exhaust
- HKS intercooler (very thick)
- Single plate brass button clutch
- Nismo 2 way mechanical diff
- Turbosmart 38mm Plumb-back BOV
- EMS stinger ECU
- Bosch 044 in tank pump
- Nismo 740cc injectors
- Catch can with braided lines
- 18" Drift R wheels (can sell with 16"s for less)
- Rego till September
- Fully engineered!
Thats all I can think of at the moment. The car is very clean and tidy.
PM or call on 0417 438841
Edited by turbo87
The car looks nice in the photo's . I looked at it when the other guy had it and it was abit sad. Did you fix up any of the paint work ?, have trouble with the engine ? , not that it was all that bad in the first place
Yeh the bonnet, front bar and front guards have been painted, the engine's been rebuilt and there have been a fair few other changes.
Much more presentable car now, not that as you say it was ever that bad
Hey man, could be quite interested. And in a perfect location of about 20 mins from me.
Standard suspenion or coilovers?
Any brake upgrades to help slow this missle?
Any cam upgrades? Shafts? Gears?
Thanks champ
Car did run a 12.2 on street radials - couldn't get traction but ran either 122 or 124mph (can't quite remember)
The suspension is standard - I have both std springs and reset ones (as in the pics)
Car has high quality brake pads and cross drilled front rotors (done about 100km)
Car has standard cams however I have a pair of Poncams sitting in my room that we might be able to come to an arrangement on
The car had the inlet/exhaust manifolds removed and I have just re-fitted them.
The motor is 5000km old (about 12months) and was built by a friend who is very experienced building motors.
I have receipts for most of the gear, pistons are 20thou
What sort of fuel economy do you get?
About what RPM's does the boost come on? Is it pretty sluggish down low? I wouldn't mind seeing dyno sheet if you've got it scanned.
Cheers!
Not looking at swapping for another skyline,
can scan the dyno sheet on the w/e although your sig says you've already got an r33?
Boost starts high 2's and hits full boost about 4k
Had an R33, sig fixed. Don't worry about scanning it, I'm probably after something that comes on earlier. I guess I was dreaming that an rb25 with this much power could spool up early :sorcerer:
Thanks anyways!
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
