HI guys the names Andrew I've been round this site for a while now but on the weekend I finally go my first Skyline. I flew up from Melbourne to Sydney to view it. It's a 94-95 M-Spec with approx 108,XXXkm on it. IT does have a few cosmetic issues but my uncle is a panel beater so hopefully it will get fixed up for cheap. The car also has the books from Japan so I was happy with that. PIcked it up for 10.5k
Here it is:
http://www.skylinesaustralia.com/forums/in...howtopic=156036
It has a lil bit of work done, with a boost controller, short shifter, cannon (I need a full exhaust), and some lil stuff like alarm, boost gauge turbo timer etc...
I have a few questions in regards to it im sure these are common problems and Ill get some answer right away.
1. I have a leak in the boot on the passanger side and there is a lil bit of water coming in (no rust though). Is this a common problem? And what could be the culprate?
2. The head lights have like a faded brown look to them can this be fixed or do I need to buy new headlights?
3. The drivers side power window switch works when it feels like I presume its just the solonoid???
4. What is safe boost to run on what is essential a standard car? It seems to be runnin around 10psi at the moment.
5. Passanger Side Seatbelt doesn't retract when u get out can this be fixed or will I need a new one?
6. Based on what it has done what would be some basic mods that are worthwhile doing? Mainly performance wise.
7. Hey I was reading that these come with 4-Wheels steer I didnt notice mine workign How can I tell??
THnaks everyone and I hope I dont annoy you too much with what I presume are pretty standard questions.
Edited by zorb_rules
https://www.sau.com.au/forums/topic/160048-just-got-my-first-skyline-an-r33/
The headlights you can clean by just doing a cut and polish job on them, quite a few older skylines have this issue and they polish up real nice
10psi is perfectly safe to run on, I wouldn't go past that for daily driving really because you won't feel any real difference. If you must up the boost, just don't go past about 13-14, like I said tho, I wouldn't bother.
As for mods, upgrade fuel pump, injectors, buy a Z32 AFM and an aftermarket ECU and get it tuned :P
Here it is:
1. Probably leaking in through one of the taillights. Might need to be removed and resealed.
2. Fading happens all the time on r33's and r34's. Use some brasso to polish them clear again, then finish with meguires plastic X polish.
Doesn't fully get rid of the yellow colour but is a huge improvement.
3. Could be the solenoid. I'm pretty sure the motors are common to fail, but don't quote me on that.
4. 10psi every day, only after you've got yourself a turbo back exhaust though. If you don't have one, then leave it at 7psi.
5. Beats me. Probably just get one from the wreckers.
6. In general the basic mods to do are: Turboback exhaust, bigger intercooler, boost controller, ecu or piggyback computer, pod filter (if its what you like), Possibly the fuel pump because they're getting old and can't keep up sometimes.
7. It's called HICAS. It only starts to operate at about 80kmh+. It is different to the 4 wheel steer on hondas and other cars. The rear wheels turn in the same direction(not opposite) as the front wheels. They only turn about 1 degree. It is fitted to improve handling rather than as a parking aid.
Thanks guys one more quick question....I get this clicking from udner the dash when I turn the car on..or when I use the demist option on the climate control...the guy I brought it off mentioned somethin about the cogs that moves the vents or something...i dont really understand maybe you do??
This is common in skylines, I think it is normal and not a problem....
Also, your car is not an M-Spec.... Its a Type M.... pet peeve sorry.
As far as the faded headlights go, you could scrub till the sun goes down and they will never look clear like the lights on a SII r33, maybe some aftermarket headlights or r33 GTR lights will look a lot better...
http://www.fizzautosports.com/lighting/lig..._headlamps.html
The ones on that site (towards bottom of the page) look better but the price is crazy... im sure there are better options that are similar.
For the headlights.... start with a 300-400 wet and dry and work your way up to 2000 (using all grades wet).... then cutting compound, then silicon free polish. I do it all the time for work...
Yea dont worry about the noise that you hear from your dash when your abou to start it, tahts got to do with the air con.
  • 3 weeks later...
Mine is doing this as well now... exactly the same... rather irritating... have to pull it all apart one say and see if i can fix the problem. It's as the seller mentioned, the motor that moves one of the vents is stuck or something... when I get around to fixing it i'll let you know!
do i do the inside or outside of the lights?
Outside...
inside would involve taking off the front bar, opening them up, then re-sealing them... not an easy job to do and can take a whole day...
dirty headlights are something i wont tollerate, so go and clean them!
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
