.....Who's car can run 10's flat...and do they use it everyday?
Brother inlaw ran 10.21 @137mph RX7 S3 13BT untubbed street driven. :)
Previous to our skylines we had RX2 12A bridge and it was the most fun I have ever had driving that thing,
hubby used to complain I had no mechanical sympathy, but it kept going and going.
too many variables with drag cars.
if u look at the pro rwd category in sport compact racing worldwide, pistons r the clear leader with titan running 6.41@220 in their 2J scion, theyre just making too much power for any rotary engine to catch.
at the end of the day, nothing beats v8 twin turbo :) no1s yet to catch MRMAD in australia :) and thats only a 3/4 chassis car!
yeah sports compact cars can only go as fast as to a certain degree.....
You'd probably find that the quickest cars come out of Puerto Rico.
Here's a video of a quick RX8, did a 6.81 @ 200mph in August 2005, and that still wasn't the quickest car at the time. http://videos.streetfire.net/Player.aspx?f...p;kw=11&p=0
Now thats what I am talking about :sorcerer:
A real car driven on the street...not a car that can't turn a corner :sleep:
RX7's have one of the best chassis for drag racing...this is why they are stripped down and re-built .
  • 2 months later...
Fuel consumption however is high
This is true on stock models but as the power goes up, the gas mileage doesn't go down much. In comparison to a piston motored car anyways.
im not quite sure why everyone keeps saying they're so unreliable...there are 2 guys at my works with a rx3 and rx4 and both claim its been about 160000ks without a rebuild now
I owned a 1987 RX-7 Turbo II with a few small modifications. I got 190,000miles on the odometer before the engine seals blew due to the radiator dying. One of my buddies owned a NA version of the same car and hit well over 250,000miles before the car rusted apart (lots of snow here, and they salt the roads). The normal problem with reliability is that the seals which hold the housings together go bad, which causes coolant to get into the engine. Coolant, being mostly water doesn't compress or combust, which kinda ruins your engines day. Rotary engines self lubricate when they run (they actually burn nearly 1 quart of oil every 3000miles), but most people just have the cars as weekend rides and they almost always sit in the winter. Sitting for extended periods of time causes the seals dry up and thats where the reliability issues come in. You rarely hear to many problems coming from daily driven RX cars.
Does anyone know what time the quickest rotor in the world does down a quater mile ? and what makes them so good compared to piston motors ?
I don't know what the fastest rotor is, but the reason they are so good is that they basically only have 2 moving parts (the rotors themselves). Because of this, there is a lot less to break. They are also way more efficient because they do intake, compression, combustion and exhaust all in the same chamber. Also rotary engines are VERY lightweight and they take very well to modification (big honkin turbos and whatnot).
No doubt in my mind that the Wankel motor would be superior to its piston competitors if people had spent the same amount of time developing it over the last 100+ years as they did the internal combustion piston motors. Heres some more information for anyone who actually cares. http://auto.howstuffworks.com/rotary-engine.htm
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
