.....Who's car can run 10's flat...and do they use it everyday?
Brother inlaw ran 10.21 @137mph RX7 S3 13BT untubbed street driven. :)
Previous to our skylines we had RX2 12A bridge and it was the most fun I have ever had driving that thing,
hubby used to complain I had no mechanical sympathy, but it kept going and going.
too many variables with drag cars.
if u look at the pro rwd category in sport compact racing worldwide, pistons r the clear leader with titan running 6.41@220 in their 2J scion, theyre just making too much power for any rotary engine to catch.
at the end of the day, nothing beats v8 twin turbo :) no1s yet to catch MRMAD in australia :) and thats only a 3/4 chassis car!
yeah sports compact cars can only go as fast as to a certain degree.....
You'd probably find that the quickest cars come out of Puerto Rico.
Here's a video of a quick RX8, did a 6.81 @ 200mph in August 2005, and that still wasn't the quickest car at the time. http://videos.streetfire.net/Player.aspx?f...p;kw=11&p=0
Now thats what I am talking about :sorcerer:
A real car driven on the street...not a car that can't turn a corner :sleep:
RX7's have one of the best chassis for drag racing...this is why they are stripped down and re-built .
  • 2 months later...
Fuel consumption however is high
This is true on stock models but as the power goes up, the gas mileage doesn't go down much. In comparison to a piston motored car anyways.
im not quite sure why everyone keeps saying they're so unreliable...there are 2 guys at my works with a rx3 and rx4 and both claim its been about 160000ks without a rebuild now
I owned a 1987 RX-7 Turbo II with a few small modifications. I got 190,000miles on the odometer before the engine seals blew due to the radiator dying. One of my buddies owned a NA version of the same car and hit well over 250,000miles before the car rusted apart (lots of snow here, and they salt the roads). The normal problem with reliability is that the seals which hold the housings together go bad, which causes coolant to get into the engine. Coolant, being mostly water doesn't compress or combust, which kinda ruins your engines day. Rotary engines self lubricate when they run (they actually burn nearly 1 quart of oil every 3000miles), but most people just have the cars as weekend rides and they almost always sit in the winter. Sitting for extended periods of time causes the seals dry up and thats where the reliability issues come in. You rarely hear to many problems coming from daily driven RX cars.
Does anyone know what time the quickest rotor in the world does down a quater mile ? and what makes them so good compared to piston motors ?
I don't know what the fastest rotor is, but the reason they are so good is that they basically only have 2 moving parts (the rotors themselves). Because of this, there is a lot less to break. They are also way more efficient because they do intake, compression, combustion and exhaust all in the same chamber. Also rotary engines are VERY lightweight and they take very well to modification (big honkin turbos and whatnot).
No doubt in my mind that the Wankel motor would be superior to its piston competitors if people had spent the same amount of time developing it over the last 100+ years as they did the internal combustion piston motors. Heres some more information for anyone who actually cares. http://auto.howstuffworks.com/rotary-engine.htm
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
