It wasn't bad.. and the action sequences were awesome, but i think a lot of the best parts were given away in the trailers.. i hate it when that happens!
Definitely had a more hardcore sci-fi edge with a lot more "outside" the matrix than within.
Not much of a storyline though, and some parts were pretty "so what".. i think they cut a few corners on the storyline front, but there were quite a few leaders into the next one
Guest INASNT
Originally posted by Mildman
Most of the good quality rips of top end movies (pre release date) - are the evaluation copies given to the Academy - or for reviewers I guess.
I saw son of rajab of the Rings 1 and 2 before the hit Australian cinemas....about every 30min a caption came across the bottom of the screen."For your consideration", or "For consideration by the Academy" - something like that.
This means the Reloaded rips out there could possibly be from a DVD....
i got a few of those for your consideration dvd copies 2!
MATRIX RELOADED ROCKED!!!!!!!!! I love it!!!
The bits they showed at the Animation and Effects festival that weren't in the trailer were..... oh.... most ppl prob still haven't seen it... i'll give it a few days ;)
I reckon it was a great movie and i hope that u guys all stayed to the end and watched the trailer for MATRIX: REVOLUTIONS!! hmm!!!! :(
cos REVOLUTIONS looks every crazier!!!
hehe....yeah how long did u have to wait though to see the revolution trailer and it was soo short too. i recon i coulld have d/l and watched it in the time it took for credits to finish...lol
oh oh....and who would have thought that morpheus was neons dad!!!:D:D
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
