Hi all how has the local seen been doing down here of late it has been a long time since I posted here. Have been busy with moving and my wife having our first child (a baby girl). My question to the people in the know is this! If I was to put a fixed bucket seat on the drivers side and just a normal reclyning one on the passangers side, would it be illegal to have passangers in the back or say a baby seat? Just trying to work out wheather there is a chance of having both or if I will have to sacrafice one or the other. Thanks for any info, will be looking forward to catching up with some of you guys and gals when I get the chance.
https://www.sau.com.au/forums/topic/160113-legality-of-fixed-bucket-seats/
on the right path dan
one is fine................as long as there is rear seat access (ie recliner or stocker seat)
if u use 2, the car must be re-registered as a 2 seater BUT the seatbelts / seats must be left in
aaaaand the whole ADR approved seats on correct rails etc
Thanks for the info guys, may end up going with just the one fixed and the other reclining. Brenton nothing against 4 doors but Ive been hanging for a V-spec now for over 2 years, with a bit of luck and god willing I may finally be able to get one at the end of the year. Thanks again for all your help guys.
No NO, no offence at all.
If I had the money I'd buy a V SPec in the speed of light.
But still 4 doors are so easy to get in and out of. HAHAHAHHA.
Good Luck with it mate.
I have a fixed back Velo Bucket for sale. Wth R32 rails. Which i have been told will it R33 too?????????
Just a thought.
Brenton
Shut Ya Mouth WHang Chung. HAHAHAHAHAH
I thought I saw you the other day. But I don't think it was you as you would of most likely tried to get my attention and or yell abuse at me lol.
So I have come to the conclusion it wasn't you and there is another 33 going around that looks similar to yours.
WHAT THE......... OK CAR IS FOR SALE! :rofl: JK
Yeh right where was that? Might have been me, Where you in the Line? Would have noticed that!
Yeh i was in the 4 whore.
It was on anzacs up near Ink Pit near Blockbuster.
You no where I'm talking about.
NOOOOOOOOOOOOOOOOOOOOO Don't sel the 33.
Unles your buying a house then well we all need to save for a house and or a deposit.
Bring ur car out for the BSM cruise. I want to see it before you sell it.
Yeh was only saying that cos there was another like it! Was prob me now i think of where you say!
I'll see what i can do for the cruise, Not in much of a hurry to sell her anyways, may not even go!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
