I dragged myself to a hot rod show on the weekend. Only to discover why i have so much trouble trying to get good plates for my skyline. I have a 33, and wanted to incorporate 33 into the plate, but cant find one left that i still like. Its cause all the old hot rods have them. There was a tonne of 1932 model cars with 32 plates, as well as a few 33 plates, including QIK 33 and also TUF 33. Both plates i would have liked to get. How does a skyline driver compete with all these old fogies in their hot rods.
https://www.sau.com.au/forums/topic/160122-trouble-getting-good-plates/
I think you're generalising... I mean, well yeah sure you have a point... but it's all about popularity... first in first serve... it's just all the popular ones are taking... try something unique.... and maybe you can incorporate R33 into it. Just my 2 cents.
i have nothing but admiration for the people that build these cars. it takes a lot of time and dedication to do it. i didnt realise they were mostly built around early 1930s. yeah, they probably deserve the plates more than i do. that doesnt stop me from wanting them still, if anyone still knows of any good 33 plates let me know, thanks.
they probably bought the plates before you knew how to drive.
but yes, there is lots of money put into these cars. i would like to build a 1933 ford 3 window coupe, but i am looking at about $15,000 just for a rusty old shell with no motor, running gear, etc. and it isn't just a case of bolting stuff in. you have to custom make a front and rear end for it, then custom fit brakes, and steering, then custom make all the interior, the list goes on. my father-in-law does it for a living, so i know how much shit there is too it, and they mainly do F trucks, which are easy ones. but they still take about 2-3 months work (thats working 5 days a week on it).
Well you can get away cheaper than that by using reproduced bodies and chassis. For example, the following site has bodies for around $8000-$9000 and chassis kits which includes lots of goodies (brakes, diff, suspension, steering etc) for around $12000. Obviously works out more expensive than the $15k, but in the end it would still be cheaper than the "rusty old shell".
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
