why make your car more obvious to the cops........hey i dont care what car it is.......now i know the plates and its easy to remember, same thing for thieves, keep it plain and simple just keep your current state plates
man Id love a hot rod!!
I have alot of admiration and respect for the blokes who build these cars, I know quite a few people with them, and some builds have taken more than 10 years.
Also - if you want to see some nice rods - theres a hot rod show up at newcastle over this weekend
now - back to plates....
in NSW depending on plates - its like another 180 a year to like 400 a year on top of your rego - are they that important?
Well you can get away cheaper than that by using reproduced bodies and chassis. For example, the following site has bodies for around $8000-$9000 and chassis kits which includes lots of goodies (brakes, diff, suspension, steering etc) for around $12000. Obviously works out more expensive than the $15k, but in the end it would still be cheaper than the "rusty old shell".
but should i go to sell it down the track i would get a lot more for it if it was a steel shell, instead of glass. i have seen the glass shells before. one done up with the steel shell will sell for about $80k if done nicely.
That's what I've got, I have some good ideas for some plates I would get if I wanted to, up to 9 letters in WA FTW!! My state plates are half decent anyway, ends in 000 :( One of my mates ends in 033 on his, good timing or what?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
