1974 ta22 celica
engine: 3tgte t3 turbo
cp pistins
new valves
new head gasket
front mount
chrome engine bay
nos intake
apexi turbo timer
boost controller
microtech computer with controller
drive line: steel case gear box
stronger internal gears
LSD
race clutch (not brass button)
17" grand turismo wheels with marshall tyres
r32 4 wheels brake setup..
extras: 750hpr fuel pump,
65 litre fuel tank
racing seats and harnesses
white interior
monstar tacho (auto meter)
sunroof
all engineered...
$8000 or swap for something of interest
call me 0432564932 for for info or reply
    • Yes, the problem is the supply chain hasn't standardized on metric which makes it more expensive to source metric hardware. They're all mail order at this point. Fastenal is cheap but you can't exactly rock up to a fulfillment warehouse as a random D2C. Paying 13 USD for 3 nuts doesn't really make sense. McMaster-Carr and similar companies are all in a similar sort of boat. If you like gambling on mystery hardware Amazon is cheap too but you're going to be buying 25 of whatever screw you need. So Lowes/Home Depot ends up being the way to go if you really only need small quantities of hardware for odd jobs like trying to rebuild a power steering pump that calls for an m6x1.0 screw to pop out the flow control valve.
    • What size bolts did you use to reattach the cam cover baffles? Thinking it will need to be M3-M4
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
