I was looking at ebay turbos before I said, "f*kit im gonna get a garret and blow a few thou" and I tell you wat GARRETT/HKS > HIFLOW > KKR > REST OF CHINESE SHIT. Never lookin back. Garrett GT3076R ftw.
Edited by Pauly33GTS-t
  • Replies 40
i asked this question to ppl who already bought turbos off this one seller. most of them right up positive feedback because they recieved not because they had it installed. anyways i emailed a few ppl and most of them said that the turbos are good for low boost applications (around 7-9psi) and that they are cheap chinese copies.
i would stay away because last thing you want is one of these blowing up and then having to spend twice as much getting a new turbo and fixing any problems the blown turbo caused.
i had on a super t70 work awsome not on low boost eithre running 22psi after 2 year done a seal so i got it rebuilt but after the rebuild the turbo fail 4 month later on 12 psi the ppl that rebuilt it wont take responability for the rebuild i brought this turbo 3 years ago work fine untill someone rebuilt it i am now goin through consumer affiars so the ppl that rebuilt it take responabilty for it
i have seen t70s with a totally diffrent built such bad quality now i must have being lucky
so really its a lucky dip i now have a garrett 35/40 and i know now thats wat ill be sticking with
no point taking the risk
I asked the guys at JustJap.
They said there turbos are made by Ottomoto, same company that makes the KKR turbos.
They are basically the KKR's with different branding.
so does this make them better than the "ebay chinese copy" turbos that everyone brands most turbos with?
I believe the KKR otomoto ones are different to these ebay chinese copies.
They are nasty and cost the retailer stuff all for the T70 and other copies. From what ive seen of availablility of chinses turbos the KKR is a different beast and more expensive from the wholesaler.
Chinese + moving parts = Steer clear.....
I was going to try and challenge this with an example of a chinese made item with moving parts that is exceptional, but i cant think of any thing? lol :S
Thunbps up for the Intercoolers,radiators and some of their other parts tho lol
The KKR's are made in China from what i can gather.
Not everything out of China is neccesarily bad you know. People would be surprised to see what parts they might buy that were actually made thier and you wouldnt even pick it as the quality is good. Aust businesses wouldnt be selling stuff that would potentially bring them undone, thats just silly.
Its just the knock-off products you need to be wary off from the "unheard of" places over Ebay etc etc.
The actual *legit* decent stuff from China isnt all that bad. Its just there is a lot of crap bringing down the names of the few that are reasonably decent.
In High performance Imports Mag, they said KKR was a Korean turbo and supply Volkswagens and other cars with their turbos from memory. Apparently the KKR turbos are pretty reliable and produce good power, they're just a bitch to fit.
I'm looking at getting a turo soon too. Anyone on here bought and fitted a hypergear turbo? they are also cheap but are from Korea
also just some other notes in regards to cheap ebay turbos / cheap seller turbo's
more often that not there are some key differences
- wierd flanges or dump patterns (kkr, monsta t70 etc i dont think mate at all to standard parts and need their own bits)
- plain bearing, journal bearing (majority of the cheapies aren't ball bearing)
- oil cooled only (usually the cheapies are oil cooled only)
- lack of compressor map / details available (usually monsta STAGE 3 hiflow super wheel blah blah type jargon, no real reference to compressor trim,blade type)
but they are exactly that, a cheap alternative. im not saying the dont work but there are extra things you should be aware of and need to know if using them. some need extensive modificaitons, some dont need much at all. some require extensive knowledge for fitmet (oil line changes to remove BB restrictor) and some have extra "gotcha's" when using them over the standard turbo (non BB unit and instant car off risks bearing failure)
so sure its a $650 turbo thats capable of 550hp but look at the overall plan and solution and see what you are really getting.
with an off the shelf garrett unit you can ring gcg in sydney, discuss flange/dump options, manifolds, you can ask for compressor maps (no guess work) and work out the optimum solution, but that also comes at a price. a price for reliability, knowledge, customer support (compressor maps, blade options, housing options etc) and help
great a new turbo that lasts only 2 years! Sounds like a peice of crap.
The owner of HPI is also the owner of Ottomoto/KKR so that opinion may be a bit biased
Of course its bias. I totally agree.
Ben Ellis (ottomoto/HPI) wouldnt slander your own product now would he hehe :sorcerer:
Dont trust everything you read, especially magazines that have vested interests
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
