Is a z32 AFM a worth wile mod to do to my car with the current mods.
Factory turbo
HKS 3" exhaust From turbo + HKS Hiper muffler
HKS super flow pod filter + Cold air intake
HKS EVC 5 boost controller
Apexi SAFC-II + Dyno tune
Greddy Type R blow off valve
Autobarn88 600x300x76 intercooler
Sard Fuel pressure reg @ 40psi
Walbro 500hp Fuel pump
NGK Iridum Spark plugs at .8mm gap
https://www.sau.com.au/forums/topic/160186-is-a-z32-afm-a-worth-wile-mod/
Yes. I recently installed one for a customer on a series 2, also had a Pwr FC. He is very happy. I run a Q45/VH41 , Pwr FC +++, no problems...
Thats great, but doesn't explain where the benefit was in fitting one to your customers car
IMHO unless you are running aftermarket engine management and your factory AFM is either stuffed, or maxing out and causing a restriction, there is no need.
Sounds like you stung your customer for something he didnt need :D
