I'm trying to buy a full set of Toyo RA-1 Semi slick tyres for supersprint use.
Every tyre place I have called has quoted me dead on recommended retail price, and won't budge an cent in pricing!! The best price I got was RRP, but with a free strip and fit to mount the tyres ($60 value :nyaanyaa:)...
What gives? With any other form of retail, there is usually some discount below RRP. Does anyone know if tyre places accept motor trade pricing like other automotive places?
I'm happy to pay for normal profit margins but I can't bear to pay RRP! Yes I am a cheapass! :nyaanyaa:
https://www.sau.com.au/forums/topic/160208-motorsport-tyres/
There is very little margin on tyres, especially R-comps, which there is low volume. Best way is to make friends with a racecar team and get them to organise the tyres for you :nyaanyaa:
My company is the major sponsor for a vehicle in the Fujitsu V8 Supercar series, I think that's as close as I will get! :nyaanyaa:
Dude, I got these tyres - make sure your not doing more than 2-3 laps in a row - way to soft for any track use, they go off really quickly (great for the street/wet weather use). I won't be buying these again
Hmmm weird I've heard otherwise..
What would you use instead?
The R888's are even softer than the RA-1's arent they?? A lot of people seem to think that the R888's are an awesome tyre...Softness of the compound isnt usually directly related to the heat tolerance is it?
I'd say get another opinion, whoever told you these are good for the track is giving you a bum-steer, I've used them and they are better suited for 1 lap sprints, say hillclimbs or street use - Bridgestone RE55S are a much better circuit tyre, stonger sidewalls as well. Unsure about the R888s but I doubt they would be as soft as the RA1's - I understand the compound in the RA1's is the same as the Nitto drag radials which gives you an idea how soft these are.
I like the R888's for dedicated track use as the RA-1 are best used "buffed" as stated in all their literature, they are also great in the wet "unbuffed". I used the RA-1 on my daily and they were great for hills and occasional track days..
Edited by URAS
Yes even more reason not to go RA1's for the track - have to buff the things as their tread squirms badly (waste of rubber/$$ if ever I've seen it) + still have the soft sidewall issue.
Ive found the Bridgestones to be the cheapest in 16" and possibly might be in other sizes too.
They are also one of the most common tyres used down here. The local Bridgestone guy uses RE540s in Targa but uses RE55s on the track.
hey Jon - I know the Melb guys are picking their semis up for a steal. Perhaps drop them a line and find out why they get them so cheaply? At the prices they get them for, it might be worth getting them sent up!
Just a thought.
Liz.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
