Did an oil change today and used motul due to it being more readily available here than my regular drop.
Whilst at repco I saw an all synthetic from penrite called SIN. Has anybody had any experience with it. Going by the price it would want to be some good schizzz.
https://www.sau.com.au/forums/topic/160255-penrite-sin/
Its the one I was telling you about. 5w60 >_<
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975671
My mechanic would agree with that! He thinks using any penrite product is a sin!!!
HAW HAW HAW!!!
A mechanic I know would say anyhing else is a sin! >_<
He has been trying to blow up his 200 000km stock bottom ended 350awkw GTR for years and cant...he attributes some of his lack of success to this oil!
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975700
I used to use Penrite in my first 33....I liked it and it was recommended by quite a few workshops...I reckon this stuff would be pretty good..they seem to know what they're doing...I used Motul in my other cars though...and also found that to be reasonably good.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975710
yep, penrite has had some good history on its side. A few racing cars and been making oil for donkey's years etc....
Tried motul and switched, I've been using the royal purple and really happy with that. Great oil temp and pressure stability, good friction resistant and seems to come upto pressure quicker (than the motul i was using prior). On the skyline I think the royal purple has the history and the creds- especially with hi end gtr's etc. A lot of top jap workshops have used the royal in the past.
That's my pref, for what its worth...
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975820
A mechanic I know would say anyhing else is a sin! :laugh:
Haha, I think most of the top end oils in fairly stock cars (ie a bit of boost etc) are pretty much the same anyway.
I guess at least the penrite stuff is somewhat Australian.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975848
Redline or royal purple would be my choice but its too darn hard to source here in the switch. :laugh:
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2976280
I didn't say it was MY opinion, why is it necessary for me to back it up? I was simply stating that many people would prefer other oils over Magnatec in particular.
Oils aint oils?
Anyway i am about to try Mobil 1 5w50 in my car next service.... then im going to try the Motul Semi Synth 5w50 and see what the difference is.. i might also try a Penrite as i put it in my Gf's celica with 200,000 on the clock and it now works a damn treat..
I use to use the semi synth Motul in my silvia and it never had a problem.
Guess i will just see how it goes..
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977740
I have been using Royal Purple for the last 40,000kms and love it previous owner used ELF (not sure on details) but engine did feel better with the royal purple in it. Wont be changing to anything else from my experience so far.
Interested to know what price is this Penrite SIN?
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977910
HAW HAW HAW!!!
You would make a good redneck man.
I use 10W60 Catrol and my engine has never been better i think.....
WTF is Royal Purple??
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977980
Hmm that rimindes me, i should start putting better oil into my 200,000 stooooockoooo lancer. that isnt my dads crap "BALCK AND GOLD!!!"
plus when i finally get that lovely peice of laminated License i will be giving him a full detail :glare:
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2978267
giving your dad a full detail?
talk about keepin it in the family.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2978288
    • Thanks for the explanation, I'll sleep a little smarter tonight! Cheers.
    • Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY. He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
