How much does turbo light , royal purple and SIN cost? i my self use mobile one and have done for years. im planing on trying motul because i hear its a bit cheaper.
Most of these oils run around the 55/75 dollars for 5 litres. Money well spent.
Last time I bought my oil it was $89.99 at autobarn slacks creek I am hoping there is somewhere cheaper than that as I do think they have raised the price from $79.99 (5L) Anyone know where to get a better deal on Royal Purple?
also whats your views on oil filters I have been using the KnN ones so far are the cheaper brands as good? what about genuine?
Another vote for Royal Purple.
I have dyno readouts from a study conducted by Fast Fours or Hot Fours (can't recall off hand) showing Royal Purple topping the list for power with Mobile 1 coming second.
They used a almost stock Honda Integra and they tried the various oils in it 1 by 1 and dyno'd it with the various oils in.
Everyone has an opinion on what oil is good and for the most part nobody has any scientifically proven reason why. For this reason alone I chose to try Mobil 1 and Royal Purple and I must say that I could swear I felt the difference if thats possible.
Cheers,
Ben.
i have attached the results of an oil comparison taken from zoom magazine. i don't have the article as i have issue 109. they have printed this table at the start saying one of their previous issues (105) ran that article but the table wasn't formatted correctly
as you can see...
most power came from: nissan genuine, mobil 1, castrol magnatec, fuchs titan
least power came from: pennzoil platinum, valvoline xld
does anyone have a copy of issue 105 for more info on their testing?
Is the dyno power read out a good comparison as to how the oil protects?
no, but how can one possible determine long term protection in a clinical manner?
different engines, different condition, different drivers
it would be impossible to do a double-blinded randomised control trial comparing oil types.. that's the gold standard for clinical evidence :D
Try "Hi Octane" for a cheaper buy price on royal purple. They've been advertising a lower price than autobarn.
I got my last 5litres for $75 and that sheet (power and oil pressure) seems true on the road- I noticed a difference over Motul with more power and oil pressure and temp stability out of the royal purple
PS. REDLINE on the list is the same Royal Purple 10/40 I believe
Awesome Ivan is the man!
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
