this is the suspect plug and i have no idea where it goes. its on an rb25det wiring loom and the plug is near the afm plug. It must go to some kind of box which i dont have. I know that the grey wire is a constant power to the injectors wich i tapped into to get the engine to run. any help would be greatly appreciated. cheers
Edited by _Sawyer_
https://www.sau.com.au/forums/topic/160264-where-does-this-plug-go/
Its the main plug that connects into the body loom plug on the R33s. The light blue is from pin 19 which is for the power steering switch, the yellow is power feed to the FICD, the blue with the red stripe connects to the wiper motor and also the incabin plug (probably a power feed), the green with orange stripe is from pin 44 and connects to the neutral switch and the green with red stripe connects to pin 9 which is the A/C cut signal. The grey as you mentioned is power to the injectors.
Hope this explains things.
Cheers,
Ben
Edited by BH_SLO32
