Hi guys,
i am searching for 3 r34 gtr's for my wedding on the 24th november in brisbane,
we would like the ower to drive the car if possible and a fee would be agreed apon.
thanks
Hi mate,
Congrats to start with!
Novembers' a long way away and dedending on work schedules I may be able to help.
Got a R34 GTR VSPEC Gunmental Grey
Cheers,
Kwei
there are a lot more than 3 R34 GTRs nowadays....getting quite popular cheap
fixed it for you
i guess i mean GTRs that actually matter, like folks who have been on our cruises occasionally or do lurk our forums. Community people, not some backwater bogan mogul who bought one to enlarge his e-penis to his mates
fixed it for you
HAHAHA mel ur a classic
  • 4 months later...
Very few 34's GTR's in the club 0_o
Very few GTR's in the Club...
If you wanted a GTS-T I am sure there would be planty of people with there hands up.
PS: I need to put this pic in my post I love the bloody thing lol :P
You are going to have trouble getting a wedding dress in and out of a two door R34 gtr.
But an R34 gt-t four door would be a better fit for the dress. Just my 2 cents worth.
Good luck for the wedding!
Cheers!!
  • 4 weeks later...
  • 1 month later...
Isn't EZY34 a GT-T? Or am I thinking of someone else?
Can you PM some details, time, locations etc.? My wife is flying out that day so it will depend how it fits in around that.
I'd fly away if i had to live with you too Willo. ;)
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
