Ebay has a few for sale, not sure but there was a guy selling them here on SAU
Ebay Clear CAI kit:
http://cgi.ebay.com.au/Custom-Clear-Cold-A...1QQcmdZViewItem
Ebay Black CAI kit:
http://cgi.ebay.com.au/Custom-Black-Cold-A...1QQcmdZViewItem
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2977999
those ones on ebay rnt all that gud...
my mate said he would make me one custom fabricating a pipe to drop all the way down jus under the blinker in the gap of the grill to house the pod there he said to get it all make up and wat not will cost bout 300bux?? wat u's think
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2978873
If you are running a turbo motor, there is no point to having CAI as the air gets heated up then it passes through the turbo anyways.
Thats where the intercooler comes into effect.... cooling that air back down again after it leaves the turbo and before it enters the manifold.
Might be a bit obvious, but hey... that might help clear it up for someone :ermm:
*edit*
aaaaaand then I notice which section of the forum this is in... naturally aspirated performance hey??? *slaps forehead*
Edited by retox
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2985763
Might be a bit obvious, but hey... that might help clear it up for someone :(
*edit*
cold air compresses better, plus better off boost
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2986476
for NA cars. just cut out 1 of the intercooler pipe holes.. get some house ducting and run a duct to your front bumper. if you dont want to do any cutting. you can do a few little tricks with r33s.. i had 2 2.5" pvc pipes ducting up behind my headlight...
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2987054
i was thinking that but acually having the pod sitting low in the front bar for every1 to see
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2987924
Works great for heat soak on motors. You'll find you can sit in traffic and it won't feel heat soaked so much!
I had a polished pipe on my 32 gtst and on boost it didn't make much difference, i think i gained 5hp peak power (mind you i was runnin 20psi on a bigger turbo so less on standard turbo and even less on n/a motor) but as i said down low and on those hot days sitting in traffic the motor seemed alot happier. I had it positioned where the stock cooler was so it had that air-flow running through it also.
Plus is looks very nice if you care about the appearance under your bonnet.
They do say you have to be careful with puddles etc but i never had a problem...
I'm currently getting another one made up on my 34 gtt as we speak!
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2989242
does any1 know of any cold air intake setups for sale or any1 be able to make one or help me make one?????
here is some templates and how to do for an r33 if you want to make a cai yourself, hope this helps
cai_zip.zip
Edited by zooee
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2989928
Hey Jazza where did you get this kit? my motor hates it idling around in the heat starts to chugalug
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2989984
there is a couple of bad things about that. 1 is you will get water in your airfilter. the other fact is the longer piping means less responice. and youd have to clean it every 1000ks or less
also it means sombody could steal your airfilter and in my own personal opinion it doesnt look good to have a pod filter visable
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2990187
i still dont know wat im gonna do kepe changing my mind i may get a cold air box then run a duct from the front bar up through the intercooler hole or wat ever i cut out. ill have to get sum people to look at it to make sure nothing will be defected or anything like that, if so its favours from freinds time
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2990753
I noticed no less responce, end of the day theres still air in the piping and in an n/a u never have to build up positive pressure either!
My air-filter was as good as the day i bought it, id say if it did get wet the water would clean the thing bahahahah
Also how funny would it be someone tryin to stick thier hands in some small vent in ur front bar un-doing tiny screws to get at your pod filter. If they managed to get to the screws they deserve the bloody thing lol! I think they'd prefer to go to supercheap and get one for $20 :D
I had to have it custom made as there isn't a kit for the car bud. Personally i thought it was great and as i said there's one going on my r34 as we speak!
https://www.sau.com.au/forums/topic/160288-cold-air-intake/#findComment-2990768
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
