Hi,
The following parts are the original plastic body parts. Gunmetal in colour
M-spec Front bar
- includes lower grills, indicators and parking antenna
- no cracks
- $160
Side Skirts
- includes all necessary clips brackets etc for fitment
- very good condition
- $100 pair
I'm located in Sydney.
Edited by spio
https://www.sau.com.au/forums/topic/160299-m-spec-front-bar-sedan-side-skirts/
Hi,
I may be interested in purchasing this, but I am in Adelaide. Is postage an option or is it too expensive to worry about when considering the size of this item? Also is there any rust or grazes in the exhaust itself (ie where it may have rubbed and become thinner)?
Perhaps I should wait for something to come up that is closer...
H
M-spec Front bar
- includes lower grills and indicators
- minor grazes here and there
- no cracks
- $200
Side Skirts
- for R33 sedans
- includes all necessary clips brackets etcfor fitment
- $160 pair
Rear Pods
- for R33 sedans
- includes all necessary clips and brackets etc for fitment
- Left side pod has a small hole in it, right side pod has a small crack (less than 2cm big). These can easily be bogged up
- $120 pair
3" RSR catback exahust + hi flow cat (could be 3.5")
- stainless steel muffler, the rest is mild steel
- 5" tip
- small chip to the exhuast tip, otherwise in great condition
- great sounding exahust while not being too loud
- includes a 3 month old $400 hi flow cat welded to the exhaust (hence will not separate)
- $550
Edited by four doors
The skirts are for a 4-door I presume based on your avatar?
If they're for a 2-door, I am interested.
Nevermind, sorry I re-read the post, it is for a sedan....
Would you take $150 for the bar? How's the condition, it looks like it has quite a few scuffs from the photo, but can't really tell for sure?
Edited by ProphetR33
Parts still for sale.
Lots of sales falling through..
The front bar is in good condition minus the usual underbar scrapes and a few small scratches. Nothing to worry about
Edited by spio
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
