hey guys,
just wondering on ths pro's and con's of both r34gtt's and r32 gtr's,
been reading up on em and am hell keen on either importing or purchasing one locally within the next two months. ive got a budget of about 25k or there abouts. This will probably also be a part daily car + part weekend thing, what do you guys think i should go for in terms of power, safety, reliability etc.
any help would be greatly appreciated. thanks!
https://www.sau.com.au/forums/topic/160301-r34gtt-or-r32-gtr/
for that price you can get a relatively clean stock R33 GT-R. i paid 25K for my S2 V-spec. originally i wanted to purchase a R32, which is still my favourite GTR model. but the R33 is a newer car than the R32, yet you still get the RB26 and the ATESSA. remember that R32's are getting quite old, some as old as 18 years. so many of them would have had a hard life.
on the other hand, i find R34 GTT's to be a very attractive buy. they are the best looking of the non-GTR models, they are still quite new. they go hard, they have a great interior.
unless you HAVE to have a GT-R, i would get the R34 GTT over a R32 GTR.
Was in the same position as you are. I decided on buying a r34 gtt as they are newer and less lkely to cause issues. I have driven both and as a daily driver and prefer the r34 gtt for this duty.
providing all mods are properly done, what performance increase can you expect from all intake + extraction mods... ie full zaust, intercooler, piping bla bla...
its my understand a stock GTT will push 150ish KW at the rear wheels am i correcct? Just enquiring about how much power i can gain and for how much $$$
sorry about my clueless questions, just after the best advise and figured you guys were the best to ask! cheers!
hey guys,
Both are money pits if you have the need for speed.
Two years ago I was in your shoes gtr33 or gtt..luckily I choose the gtr.
The fun thing is there are so many things you can buy for them.
Not only has my GTR bought me many smiles and giggles like a school girl...it has held its value.
A gtt two years ago where selling for 33K+.
You will need to spend money to get a reliable gtr so allow...3 to 4K after you purchase one...that is if you have no workshop receipts.
I've already said this, but i'll say it again because some other guys have mentioned it.
if you are only considering a R32 GT-R, then get the R34 GTT.
HOWEVER, an R33 GT-R would be my recommendation. newer than the R32, much faster than the R34 GTT. The R33 GT-R is the best of both worlds. with a little haggling, you can get a very clean stock R33 GT-R for 25K-28K.
my brother in law bargained my car's previous buyer down to 25K for mine and it is in absolutely immaculate condition.
You will always need extra cash to 'fix' an R32 GTR. Spend about $20k auction price and import a nice '94 model Vspec. Spend the other $5k fixing anything that maybe wrong with it, also to cover insurance and tyres and other ORC's. If its all good you got $5k for some rims or turbos or other mods you may like to add. Although I think the R32's had a problem with the oil pump?? that the 33's have fixed. Sooooo, yeeeaaahhhh!......
Keep dreaming.... I was in Japan recently, quality R32 GTR's are VERY highly regarded over there.
My mate purchased a GTR there, and a 'nice' 1994 R32 GTR Vspec for $20k you will not find... and im talking purchase price, not including import/compliance etc etc. Such a car could be upto $30k in japan for a good one. I saw one for sale in a magazine which i took home, R32 GTR V-Spec II with 10,000km and to buy it in Japan it was 3,700,000 JPY... which is over $40,000 AUD. The car was not modified and granted it has insanely low mileage, but that price gives you an idea of the interest in good R32 GTR's.
r32 GTR because they are the only real modern classic sports car from japan apart from maybe the MX5..
r32's have an appeal that just cannot be matched in the later generation cars.
its a hairy chested neandertal compared to a GTT but my god they are brilliant!
the 32 allows a competent driver to attain zen like enlightenment as to how a true GT car should behave when you push them hard.
r32 prices are soaring in Japan and there is a lot of chaff in the hay when looking for one locally, if you can find a good one buy it!
r34 GTT is a good choice if you dont have much money to spend on your car or its a commute vehicle, the only proble for me with rwd skylines is they are just a turbo coupe, the GTR's have somthing special
but then again. I have one.. so I'm bias all the way :rofl:
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
