My names graham and am new to the site i have a 1996 r33 skyline and recently took it for a RWC.
i need to do a shit load of stuff to it and need standard parts and other things.
first of all does anyone know if there's any Road Worthy places that will pass a lightly modified car.
OK the things i need to replace are:
-exhaust to standard (i currently have a 3" and thought it was fine apparently its to big)
-New standard bumper bar (need one with the reinforcement in it)
-standard height suspension (low is cool though)
-head lights are dull (attempting to clean them with brasso)
-blow off valve vented to exhaust system
i am also after a turbo timer and boost controller
thanks in advance for anyone who helps me
https://www.sau.com.au/forums/topic/160306-rwcs-and-skylines/
- exhaust ... what the hell? is that actually a new rule now, my mate had a 4" on his and got a RWC fine
- bumber bar... this guy is playing with you, my mate has a aftermarket front bar WITHOUT a reinforcement in it and he passed RWC AND VIV!!
-head lights are dull ... did he do the test at night? lol
ok take it to a few more places and which ever one gives a list of least costly problems you should go to
These are all legit reasons to fail a roadworthy.
blow off valve into the exhaust is not a new concept..
If u look waaaaaaay back, back into the dark ages, the humble mini (in race version)
had the oil breather hose conected into an elbow on the exhaust. I wont go into the reasons, but it WORKED.
I have seen a maximuim effort street car with this mod done.. but i've only seen one!
His idea was completly different to that of the EPA
I have NEVER heard of it being done for a road worthy!
From what I can uderstand of the EPA law,
the Blow Off Valve MUST be vented back into the intake tract (like standard)
so that any/all oil fumes or vapours can be burnt by the engine during the combustion process.
Just put the standard BOV back on! that'll shut them up on that..
Exhaust..? I think that is a state thing!
I'm sure somebody would sell u one in the 'for sale' section! REAL CHEAP!
that help?
lol its really up to the each individual mechanic what they deem passable. I bet if you go to the next mechanic down the street he'll give you a whole new list of stupid crap he wants you to fix.
Ok I'm taking that advice and am taking it to another mechanic and hopefully get a more realistic list of shit to fix. if not i will have to get working turning my car to stock standard. that should be ilegal.
is $80 for a standard blow off valve reasonable
and what suspension is good to put in. don't wont to spend a fortune but wont some reasonably good shocks that can reach a RWable height.
also i need a timer and boost controller. any that stand out as being good quality and value for money
thanks to every one that's posted
except the one who said there all legit reasons for failing an rwc. Not helping
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
