hey hey, i had a pfc boost controller hooked up in my old car but when i sold it i didnt remove all the parts for it. i have the thing that you plug the lines into but not the solenoid i think it is.
i'll get some pics of what i have in the morning, but i wanted to know is it possible to buy just that part that im missing or am i up for a whole new set?
also while ive got you here, my car was running fine untill a couple of days ago when i started to get heaps of knock, like jumping into the 90's at times. its fine if im just driving around normally but as soon as i give it a hit i get heaps of knocking. i thought maybe bad fuel but if refilled the tank since and same thing happening. nothing has changed in the car at all and ive had to wind down the boost to try stop some of the kock, was running 15psi and wound it back to 12ish. whats the go with that? spark plugs?
anyway thanks for reading my longest post ever :laugh:
https://www.sau.com.au/forums/topic/160317-pfc-boost-comtroller-parts/
fiddlying around with the thing today, and i took it out with no air filter at all on it and knock was basically gone, only went to around 20. then i put my old pod on which is less restrictive and i had heaps less knock than with the apexi one ive got.
is it possible that the rubber tube running from the afm to the turbo is sucking shut, more so when i have a more restrictive intake? would this cause more kock?
when you took it out with no filter did you turn the boost back up to 15psi ?
the intake pipes standard have been known to suck in its a common problem
i wouldnt run 15psi on a standard turbo either. but whats making me think maybe thats whats happening is the more restrictive the air filter is the more kock im getting, and i saw in the pod vs airbox thread that with the airbox being more restrictive it was sucking the pipe closed.
  • 2 months later...
well the car has been sitting in the drive way since april due to an unexpected trip to court (apparently speeding deserves more of a penalty than drink driving, stupid f**kers seriously but anyway) and i been thinking about the pinging how it just started happening.
maybe fuel filter is getting clogged? would that do it? or would that just make the fuel pump work harder.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
