Hey, the car was for sale before but then i took it down because i needed it as my daily, but now i have a new car as my daily driver and the celica is just collecting dust in the garage....
I have a book full with reciepts for this car, and thats pretty much just half the stuff its had done to it, in excess of $20,000 has been poured into my first baby.
For sale: 1989 Toyota Celica SX
Condition: Excellent, all parts (except then motor itself) are LESS than 20,000km with the majority less than 8000km.
Price and price conditions: 12,500ono
Extra Info (ie mods/history etc etc)
Exterior:
-Full respray Toyota Super Red 2
-17inch Kspeed Siefers rapped in 225/40 Kumo Esta rubber
-Tint-a-car Darkest legal tint
-removial of aeiral and genuine gt forrester scoop
Suspension:
-new mcpherson stuts
-new pedders sports ryder low springs
-new bushes all round
Engine/gearbox:
-2nd gen 3SGTE 2.0L twin cam (110,000km)
-ct20b turbo from st205 celica, with full rebuild, new steel exhaust wheel and hiflowed with garret 400hp compressor wheel (less than 100km old, not 100,000km)
-bosch 040 fuel pump
-stock 440cc injectors
-FMIC 600x330x100mm with custom piping
-s/s tubular manifold
-s/s 3inch dump w/ 3inch mandral bent exhaust, hi flow 3inch cat and genuine hks cannon
-greddy style oil catch can (doesnt breath, new intake didnt provide the stock breather)
-straight intake with pod
-microtech lt8s ecu w/ handcontroller
-turbomart dual stage boost controller
-blitz bov
-sv53 gearbox
-h/d clutch
Interior:
-Full retrim in charcoal grey (seats, dash, new floors, roof lining, door inserts i mean everything...)
-momo race steering wheel
-Autometer boost, oil and tacho gauges
-greddy turbo timer
-full electic mirrors, windows and sunroof
-pioneer headdeck (was worth 1400)
-2X fusion amps
-2X alpine 12inch type R subs
-fusion 6.5inch fronts
-pioneer 5way 6X9
-battery relocated
-auidogod equalisers
-autowatch blue series alarm system with motion sensors and remote central locking
Maintance:
-new timing belt
-new water pump
-new dizzy seals, rocker cover seals, turbo oil/feed return seals, new oil cooler seals, new rear main seals, exhaust manifold/turbo gaskets
-new s/s braided lines to turbo
-rebuilt power steering pump
-new oils (engine w/ fileter, gearbox, clutch and brake bled)
-new slave and master clutch cylinders
-many more...
Performance:
-tuned by tim slako at west racing
-pulled 267fwhp with old turbo set-up, 300fwhp should be expected with new turbo
-13.02 @180km/hr w/ old turbo (2.2 60 foot time), i wont be taking it down again but it should be a easy 12s car now, if driven right
-this car really surprises alot of people on the road
Just a quick note, alot of time and money has been spent on this car and i hope it finds a nice new home but just as an example, little things like brand new red seat belts were installed (250bucks worth!) which most people cant be bother spending money for, it is things like this that i did just to make the car what it is.
Contact Details:
pm here or ring/msg me on 0417948746
Delivery & Conditions of Delivery:Bring the cash and drive away with no more to pay...
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/160318-toyota-celica-turbo-gt2/
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
