HEY boys & girls
long story short.. i need a new engine... my car had an rb20det but yeah it died.. should i get another one.. for about $1000 or sh0uld i get an rb25det? they are newer, bigger & better lol ect.. how much more would i have to pay? $2500 for the rb25?.. has anyone got an rb25 for sale? :laugh: would it go in fine? no problems? :w00t:
and another thing.. i have about.. $3500 BUDGET :ninja: thats for the engine and install ..and prolly one of those major services ect. like timing belt and the oil and fluid top ups ect :rofl: lol i would shout u guys a carton and a good time if u wanted to meet up somwhere and do it all :laugh: i need to get in the circle of LOVE!
im lost without my r324door </3
haha does anyone have a flat bet tow trucK? ... just putting it out there :)
LUB JEZ <o/
Edited by 32JEZ
https://www.sau.com.au/forums/topic/160327-rb20-or-rb25/
  • Replies 47
following on from the PM's, I would recommend the Rb25 but not sure of whats needed in the gearbox department whether it bolts straight on or not.
3500 budget for a rb25?
nope... keep walking... you would ( while its open) replace any worn parts etc on the engine and possibly do the clutch at the same time ( since its all open)
for a rb25 ( + the ecu and wiring loom since the putahs are different) i would be looking at an upwards of 5000-15000
I got a few places to put a quote for me when i was thinking of putting an RB20//25 into my silvia and they broke down what needed to be done and what is reccomended..
they were not to far off each other and yah.. cheapest was 5000 and the most expensive was 15000 ( 15,000 was a complete rebuild + "bullet proofing" + after market gear)
So with your price range get an RB20 and do it right.
https://www.sau.com.au/forums/topic/160327-rb20-or-rb25/#findComment-2977750
+ 1. normally all the wreckers sale for 5G.
https://www.sau.com.au/forums/topic/160327-rb20-or-rb25/#findComment-2978280
I dont know much about the price ranges and acually bolting in the Rb25 but by the sounds of it, if you get a new RB20 and luckily you'll do it right and have some exra dosh over to get some nice upgrades.
https://www.sau.com.au/forums/topic/160327-rb20-or-rb25/#findComment-2978308
stoking a 20 to a 24 is more effort than it's worth and it's not cheap anyway! With your budget, just stick to putting in a 20 again. You're going to have to pay someone to take it out, someone to put it all back in....and depending on where you go you'll use up your budget quicker than you probably think. Remeber he's not doing any of this himself....I assume? If you're LUCKY you'll have a bit of left over money for some bolt ons.
https://www.sau.com.au/forums/topic/160327-rb20-or-rb25/#findComment-2978673
    • I chose a bad time to buy, at the time there was no gtst's for sale in NSW and my options were qld, vic, or sa and not the greatest examples or too far out of my budget. Ended up picking this one from adelaide sight unseen and got a bit stitched up as you could expect but i dont fully regret it, its just a shame people cant be more transparent in this day and age.
    • IMO just buy a whole R33 transmission and swap the whole thing. Use a palm nailer/air hammer with a roll pin punch to drive the shifter rod end roll pins out. The rod end is discontinued so don't break it. Use gasket dressing on the OEM paper gasket instead of RTV. I personally would not pry on the shifter cover tabs, I broke one trying that instead of just smacking the side with a dead blow rubber mallet to shock it loose from the RTV the last mechanic applied. If you can't get the flanges totally clean and free of any residual RTV and/or you might have a gap that is bigger than it should due to flange damage use RTV on that surface instead of the OEM specced anaerobic sealer. Anaerobic sealer is most likely the right sealant for the job, it's just too easy to mess it up with too large a gap or bad surface prep/roughness seemingly. If you do rebuild what you have it's for a whole gearset that can take high torque. Don't bother with OEM at that point.
    • Little hose. Big hose. They're all waiting to kill the engine.
    • Nice ride, hard to find these days!
    • Full e85 barrell stuff real world for reference if it helps as Ive pushed 2 x sets injectors to limit Above mentioned Bosch 1480cc run on 4 bar base to the apparent 1650cc on rb2.7 yielded 912hp / 684  kw  at 92% duty on hub dyno ID1700's - RB 2.8 ...1015hp / 760 kw at 87% duty - hubber dyno + shown off data on track my opinion IF you change injectors just go bigger than you think you need the modern/ good larger ones run just fine if tuned properly even if way bigger than required even on streeters
