hi, i am having a problem with my drivers side door.
when i park it in the rain, water gets into the door, and then when i open the door there is all this rust coloured water on my door step area.
at first i thought i may be getting rust under the back skyline plastic but when i lifted it, it was fine.
i checked and the drain holes aren't blocked :D (that would be an easy fix)
the rust coloured water seems to be escaping through the plastic at the bottom in the gap where the plasic pannel screws onto the door.
What could be rusting in the door? the door itself? or would it be the window winding mechanism? (sounds expensive)
it looks like the water is getting into the door where the glass is, the fabric stuff doesn't seem to be touching the glass.
would that be how the waters getting in?
Thanks!
https://www.sau.com.au/forums/topic/16033-drivers-side-door-filling-with-water/
Not good.
Even if the water was getting in the door from where the window is, it still should drain straight out the bottom.
Pull the door trim off and have a good look in there. There must be something in there blocking one or some of the holes :D
That's all I can think of :(
J
The creeking noise from the window is a common thing on Skylines - it's normally just loose bolts on the mechanism - you need to remove the door panel to fix.
Over time the rubber/fabric guide wears. It should push up against the glass, if it doesn't water, dirt and anything else can easily get inside the door.
I'd suggest having the door panel removed so that you can fix the creeking window, check for any rust/damage and replace the fabric guide...
Cheers
Dave
I think that the windows are one of the weaker points of Skylines, particularly since they use a frame-less design. The glass has to be pressured against the rubber trim in order to form a water-tight seal and I think this causes problems.:P
I had a similar problem on my old car when I first got it and it was only 6 years old at the time...;)
Still, having the door panels removed aint that much a job and I took the opportunity to have some better speakers installed along with a load of sound deadening material too:D
guys i had that water problem with my old car it wasnt a skyline i found that when the tint guys did my window all the access tint shit sat on the bottom of the doors and got stuck
alot of shit can stay down there i reconmend you get your self a screw driver open the trim put some water down and see how you go
should be fine =)
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
