Just mostly out of curiosity I am wondering if any 260RS owners could tell me what their part number on their engine ECU.
I would assume that it will be 23710-26U00 or similiar (ala R33 GTR) and obviously RS-Four will be 23710-0V??? but my engine ECU number is not even close to either of those. I suspect it is R34 but not sure................
Anyone?
https://www.sau.com.au/forums/topic/160345-260rs-engine-ecu/
Stageas use hybrid R33/R34 ECU's.
The plug on the RS4's is R34, so id assume they did similar with the 260RS's. You might also find that the tune on a GTR ecu vs a 260RS ecu is also slightly different. What they did in RS4's was improve torque a little at the compromise of some top end power.
I know but everything I have found wiring wise, as I have just replaced EVERY scrap of wiring in my RS-Four with 260RS wiring was XXXXX-26UXX which is R33 yet the ECU was 23710-0A??? which is R34-ish.
I should mention I suspect the engine is an R34 GTR unit
hi trukboy,
Im assuming you have an RS4 that you are trying to make a 260 replica with?
I dont know if a 96 model 260 was ever made, but mine is a 97 model, which branches the gap between the last 33gtr being made and the start of the 34s, mine has parts from both, is a 33 block but the clutch set up is 34, so they definitely made a hybrid unit when doing making the 260.
Where abouts is the number you are looking for? I can see if i can check the computer in my 260 for you.
Your valley cover is a bit intersting having the GTR cover on it as the 260 wasnt released with that cover, not being a gtr of course.
R33 GTR and r34 GTR clutches are the same, both pull type
The engine could just have a R34 cam cover, but the best thing would be to FAST the engine number
There was a change over in there somewhere between push and pull types, the change was towards the end of the 33's run.
FAST the engine number??
The change over was on the late r32 GTR's 1994 models, not the R33's
FAST is the Nissan parts number system
You can enter a Vin number or engine number to verify what type of engine it is or if the car was a genuine 260RS etc or a fake
Some people on here have it installed
hi trukboy,
I have reshelled a 1998 260RS into my 96 RS-Four. The number I want to check is on the ECU itself behind the LH kick panel. Unfortunately I don't have FAST but if I can find the engine number perhaps someone can check it for me.
Thanks Grim
Thanks Grim
FAST will be able to tell what ecu it is aswell
PM Alexcim, he has it
JUST Curious... with all the issues us stagea owners seem to have with out ECU's having carptacularly uniquer pinout diagrams etc... why don't we just get an entire R33 loom and ECU and re-wire the bloody thing...
I havn't done much elec- work, but i guess it could be easier tan mucking around with pins et.al...and then having to go back and muck around when it comes time to sell and all that other stuff... why not just do a loom swaop and then it would be swap in swap out?
*remembers that a loom costs money*
*remembers that he would then either have to re-solder his entire loom near the firewall or run wires all the way to ex-temp sensors, AFM etc etc which are going to inevitably be in stupidly diffucult to reach places...*
...decides to muck around with pinout stuff on a piggy back computer*
never mind
I did that but I swapped a complete 260RS loom in, time consuming but no too hard.
I checked under the lefthand kick panel, number on the computer is 23710 0A903 and below that has R585 A1 7Y20.
Thanks Ben!!!! Thats all I needed. Confirms everything I needed to know. Cheers for that. Just means the 260's still run a hybrid C34/R34 ECU. Awesome :wave:
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
