Hi all;
I have for sale approximately 10 sets of WHITE LED Parker Bulbs that will fit any Nissan Skyline. They are brand new and are a generic brand (no packaging)
Many SAU members have purchased these off me; I just don't need a whole bag full of them.
Price: $10 a set delivered
Contact: PM or stan{at}2evolve.com.au
Thanks
Stan
Just found a bag of em at home; I don't even know if there's 10 sets there to be honest (looked about it). They don't have any packaging whatsoever but they do the job....
