  • Replies 49
Bugger, I want to come and watch, but I have to work in the morning, bloody golfers!!!
I can't get there until about 12.30'ish so what do i do? I think ZX2NV is having a run, should I get a pass from him?
PM sent Wayne.
Can all drivers please post how many of their tickets they have left and who they are bringing from SAU so we can give out the spares to other SAU people?
I'll start:
3 family members of Mysteryman
2rismo
spare - invited nuffsaid, waiting to hear back.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
