R31 GXE 1987
5spd silver top RB20DET
re-mapped ecu
full 3 inch strait through exhaust, fake cat housing.
big wanna be Hybrid FMIC polished custom piping.
series 2 RB25 turbo
walbro 500HP fuel pump
GFB bleed valve/boost controler
6 puk heavy duty clutch
28 spline diff with mini spool
S13 tear drop wheels
k-mac suspension on king springs
hi flow greddy cold air intake pipe.
small boost gauge
sports steering wheel
comments: the ecu was already re-mapped when the engine was bought, it runs quite lean but hasn't ever missed a beat..
it" last run on the dyno at boostworx it made 179RWKW on 9 pound...with micro-tech or possibly power fc it should be good for near 200RWKW according to sean.
the outside of the car is reasonably clean, few small dents and scratches as usual. but nothing major..
it's red over grey with a black bonnet.
inside is much the same.. with a good clean it always comes up fairly neat.
KNOWN PROBLEMS- the gear box has/is developing noise and i have been told that it's on the way out...how ever it stil drives o.k and never slips out of gear, just have to be smooth with changes...
front left wheel sits in a bit from the gaurd, could be control arm or cross member or something down there needs replacing. it is not enginered for the RB20DET but that isn't to hard to do.
off the top of my head that's all i can think of...will edit if i think of anything else.
now then down to business...asking price for whole car is 6500 NEGOITABLE
Cheers.
Pics will be up soon.
Edited by skylineguy19
https://www.sau.com.au/forums/topic/160377-sa-r31-gxe-with-rb20det/
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
