  • Replies 60
Chris, PM replied.
And cheers Taffrey.
Matt I like the Maximas, especially the Ti, but the boss has her heart set on a Subie. Cheers though! :) Happy to sell to you for cash! :thumbsup:
Mark
tempting...
ill be keeping an eye on this over the next couple months,
might be able to take it off your hands once i get my finances sorted (again...)
Cheers lads, all PMs replied.
Hopefully I'm home from work early enough tomorrow, so I can take (and post) a few underbody, interior, and engine bay pictures for those that asked to see them.
Mark
As a few blokes have been asking why did I respray the car:
When in Japan, some the sphincter of the universe at the caryard decided to forklift it around rather than drive it. Using the forklift crushed the outer sill panels and by the time the car arrived in Aus the panels were starting to corrode and were heavily damaged.
I bought new outer sill panels from Mr Nissan Japan and had a bodyshop fit them. As I was paying for the entire interior to come out for the sill panel replacement, I decided to go ahead and respray the car, replace the right rear quarter and rear quarter glass on both sides.
Hope that helps!
Cowie
Yes I did thanks, but I ended up buying Raw111's R33 GTR Vspec last weekend instead.
Good luck with the sale of your car though, its definatly a good buy.
Cheers,
Ian
I was really looking for a freshly rebuilt car, but this is a good price and the paint is great, so can you just tell me if the fluctuations of up to 10 psi (assuming psi is what was used to gauge) are big fluctuations or whether we're talking minor damage or we're factory condition (145 140 150 145 150 150)
It depends entirely on how the test was done. If it was done cold and dry as most people do them so they don't burn themselves, well the results are fine.
Keep in mind that an alloy piston grows in size when it heats up more than the engine block does, so ring seal and piston/bore seal improves with engine temp.
If these are the results of a wet test (tablespoon of oil in the cylinder to aid ring seal), then this might indicate an issue. In the scheme of things 10psi is nothing.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
