yo guys
just a quick question
some of the intersections have Redlight and Speed cameras
so if u run a red light & speeding...u get pinged for the red light PLUS coping the speeding fine
but what if you just speed through a greenlight?
will you get pinged for speeding? or will it only ping you if u run the red light and speeding at the same time
coz i got flashed (at night) speeding through a greenlight...
https://www.sau.com.au/forums/topic/160380-red-light-cameras/
I wasn't aware that red light camera's could book you for speed. My understanding was that they are specifically calibrated for detecting red light runners, and speed camera's specifically for speed. With all the legalities and controversy over camera's not being correctly set up or working properly etc. I don't know if they would risk getting one camera to do both. It may also be different from state to state.
I believe that yes they do get both speed and red light, if you go through speeding on a green light, I would say it would book you for speeding. Atleast, that's how I approach all red light cameras, not worth taking the chance to test out the theory :glare:
My first & only speeding fine was from one of these red light+ speed cameras :glare: & yes it was through a green light. So prob expect one in the mail in the coming weeks andz69 :laugh:
FYI: Fixed speed cameras are usually set at 11-12kms p/h above the speed limit ;)
i got flashed when i first bought the car...last Xmas...has been 3 months...
so i guess it doesnt register if its green?
yeh, they do ping ya for speeding
and it takes its time..................its only the ones that say they're red light and speed camera intersections that will do it (which is pretty much all of em now)
Yeah I've always got the impression that they can do ya for Red Light and Speeding (Speeding no matter what colour the light is at the time).
Tis why I always keep the speed down through those intersections.
Good luck mate!
Good luck mate!
yah so do i..always slow down when going thru the lights
but this particular one was hidden amongst the tree branches, and it was at night...on West Tce, opposite Heaven/Hindley St
look out for it..see if you could spot it next time u drive pass
u serious? do u drive blind? on all red light camera's it says 'red light and speed camera' on a big sign!!!???!!!
by law they have to tell you what they are, so if the big white sign with blue writing says: "Red Light Camera" it's only a red light camera; if it says "Red Light & Speed Camera" then its a speed camera 24/7, and a red light camera when appropriate. If you go back past the intersection and see what it says, then your going to know what you can get busted for. =)
safe travels =P
Edited by Fishpaste~
been,there done that........and get ready for the fine.... the trafic light camera ones always come LATE!
agreed!
i have a good mate who works in the force, he tells me that the traffic light camera fines/offences are unfortunately always taking their sweet time....before they arrive in the mail box
another interesting point to mention is that the same mate reckons that these red light & speeding cameras have a tendancy to malfunction if they experience excessive heat. i think he mentioned they tend to fail after 38 degree or higher temps!.... anyone else heard this?
its just interesting to ponder the fact that each of these red light cameras cost alot of money.... (upto $250,000 each i think it is?) and to think...with all that money going into them...you would expect them to be weatherproof.
just my two cents!
in saying this though, i still hope you dont get fined there andz69...goodluck mate!
Edited by R33LIN
agreed!
just my two cents!
in saying this though, i still hope you dont get fined there andz69...good luck mate!
yeah but due to vandals they stick them in a big pressure cooking hotbox ... not trying to justify just find reason
imo best to just slow down through all intersections thats where crazy ppls try and make up time
cheers Steve, :)
you bring up some good points...though i believe its best just to stick to the speed limit at all times (i know its tempting..especially in performance cars). correct me if i am wrong, but ive heard that there is a 10% speed limit "cushion" before you get fined??, but how do we know that our spedos are actually calibrated 100% precisely..best just to stick the limit for peace of mind...and no hassles.
cheers,
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
