I have a few items for sale, they are just laying around and I'd rather get rid of them and get some cash. Items as followed.
Items:
RB20DET Exh cam shaft $50.
Standard RB20DET Int and Exh cam gears $20 for both.
RB20DET Intake Manifold without throttle body $60.
RB20DET head without cam's or cam barings $50. Still has the lifters and buckets in there.
RB20DE Fuel Pressure Regulator $20. I replaced mine thinking this one was stuffed, but made no difference so this one works just fine.
RB20DET AAC Valve x2 $30 each. Both work just fine, one came of an engine thats done 90,000. The other off an engine done 115,000. The older one is missing the o-ring and screws but if your replacing yours with this, then just take it off yours.
Speco Volt meter $15. Worked just fine when I pulled it out. Light and bracket still with it.
Sound Supressor. $15. Stops altenator noises. Worked when I pulled it off.
Location: Stanthorpe. Pick up or post on a couple of the items. You might get lucky and I'll be coming to brisbane in a few weeks and I'll take it to you for an extra $10. Post at buyers expesnse.
Item Condition: All of them are fine. Perfect order.
Reason for Selling: I dont need em, and need some cash.
Price and Payment Conditions: Cash.
Pictures:
Contact Details: PM me.
https://www.sau.com.au/forums/topic/160393-rb20det-and-de-parts/
    • You would probably do a lot better in a claims process then most people. When I called the insurance company, they were surprised I read the pds because according to them almost no one does lol.
    • Yeah it should be, but I wouldn't be surprised if the insurance company tries to pull some argument out of their ass to avoid paying you out.
    • On some cars like MR2 Turbos they're notorious for not letting the wastegate open far enough to avoid overboost, especially certain cheap downpipes. If adjusting "percentage cycle" fixes it then it's just an electronic control issue, not a hardware one.
    • Same.  It's depressing to say this but the skyline can go months on the charger between drives.
    • I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features - choose battery chemistry other than lead acid (most of mine are AGM) - power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future. The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
