Hey all.
Like many im building an rb25/30 hybrid but im stumped trying to find new rb25 head stud bolts. Has anyone been able to get them or are people just taking the old bolts to a bolt store and asking them to match it in a high tensile?
Cheers for your input
https://www.sau.com.au/forums/topic/160410-rb25-head-studs/
autobarn is the only place i know that can order them in from rocket. Rocket has to get them in from overseas taking about 2 weeks and costing about $300. They also cant get head bolts only studs and nuts. I was hoping there was an alternative.
https://www.sau.com.au/forums/topic/160410-rb25-head-studs/#findComment-2978583
