can somone please help me, i posted a few days ago but no one seemed to know anything as there was no reply!
i have taken the bottome end of my motor apart with the head still intact on a engine stand with the intention of replacing the big end bearings and main bearings and thrust washer and the oil pump also. everything is appart. bearings have worn a little but i guess you would expet that with 100,000 kms and a heavy foot for a least 40,000 :happy:
there a no deep scores in the bearings just slight wear (coulor) and the crank looks perfect, it will be getting crack tested and the journals looked at to be positive that its fine.
my problem is that when i spoke to nissan and tried to order bearings the told me when ordering standard bearings i need to cheak markings on the crank and main and con rod caps and compare this to a chart and work out the grade i need for each bearing. they faxed me a graph but its in japanese and i cant make any sense of it.
PLEASE SOMEONE HELP ME!!!!!!!
https://www.sau.com.au/forums/topic/160421-rb25-engine-bearings/
when you buy the acl bearings.... standard size not oversize i think its the same as nissan, they grade the bearings depending on the markings... think it may have somthing to do with balance or the exact circumference of the journal.. i dunno, all i know is when you buy a standard bearing you need to know if its a garde 1,2 or 3??
wel nissan have told me i need a grade of bearing, those markings on the front end of the crank on the conrod caps, on the side of the con rod, on your main caps.... they are there apparently for bearing grades. i know if i get the crank machined to 10thou oversize i can just order a set of 10 thou oversize bearings... but there is nothing at all wrong with my crank. anyone else have any idea?
yeah i spoke to the head mechanic of marooka nissan service and he suggested that because he couldnt tell me over the phone... said he would have to look at it. it just seems like such a pain in the arse to get it there... its all in parts... the head is still on the block... its upside down on a engine stand. plus i have to get time off work to make it there!!!
i really thought i could just pull it apart and replace the bearings like any other motor.... this SUCKS!!!!!
king bearings and linised crank for $300? so who did it and did you just send them a crank and they linish it and give you bearings that will fit?
Nepean Engines in Penrith.
took the crank to them, 2 days later got it back with new bearings and lynished . i think though that the mains are another brand not king come to mention it, as he said that the main force is on teh big ends not the main bearings, this is for a 300rwkw power goal which he knew about.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
