Hi all,
i turned on my R33 series 2 after 6 months in repairs after having an accident. I came to turn it over today and it turned and sounded like a rotary cutting off. I installed my FMIC (intercooler) rouughly, just enough to suck in air, added some oil and jumped started the car. The car has been off since 6 months, however about 4 months ago started it and it turned over. The car is cutting, sounds like a rotary cutting off. As the battery has been dead, maybe my powerfc computer has been reset, i dont know. the car idles very bad, i have no water in the radiator but not sure if thats the problem to why the car is making so much noise?
any suggestions to why the car is idling weird.
thanks
John
https://www.sau.com.au/forums/topic/160444-idling-problems/
Hi all,
thanks
John
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979197
Hi all,
thanks
John
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979202
i cant seem to see the problem with the car, do u have a potential solution or are theses forums arguments and commenting on pointless unrelated issues.
eh?
Hi all,
thanks
John
Ok first question - What does "installed my intercooler roughly" mean? You either install it or you dont!?
Boost/vacuum leak = idling issues
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979295
John....after being in a work shop...panel beater..etc.
I do believe your filter,afm has alot of dust and need to be cleaned.
The other thing it could be is your spark plugs...these can rust up on the ends.
They may also need changing.
Also you could be correct in assuming the cpu has re-set itself.
I am sure ,while there has been no power, some-one could have pressed down on the brake for more than a few seconds.
But if this was the case your car would idle untill it went back to factory settings.
The only other thing could be is your fuel pump might have seized or is on the way out.
Get yourself a new battery and test your fuel pressure.
Clean your plugs,air filter and afm.
If this does not work...I am sure you have an air-leak from your fmic
Hope this is a logical explanation.
OH...Put some water in your radiator...lol
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979305
Sorry to be a royal pain in the arse, however i am having the same problem with my daily driven 32 gtr, is there any way of checking for a vacuum or boost leak with out stripping everything bare? i have been putting up with this for the last couple of month's and i am sick to death of it! everything else you mentioned i have replaced but to no avail
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979323
Agree with all of that although AFIAK the powerfc doesnt have volatile memory so if the battery is removed/disconnected for a long period the PFC shouldnt lose its tune..
And.. yeah coolant in the radiator is the first step!!
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979325
You can try cleaning out your AAC valve also. This has solved hunting and idle issues for other people in the past. You will find a DIY in the FAQ/DIY section (although it is for RB25DET it might not be too different).
Are you sure you've checked all lines and piping to the IC and vacuum system? Has the vacuum lines been removed and possibly replaced in the wrong spot or similar?
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979339
Its more likely to be your afms rob...give them a knock when you have the engine running to see.
If so get them out and repair them...their is a DIY in here somewhere()
Where are you ASH..lol
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979350
Have Removed both airflow meters, as of the sensational DIY section on SAU, have fully cleaned out with contact cleaner (pc circuit board use) and re-soldered the connections eh ....
I have no idea if it has vac hoses running where they shouldn't be, i know i havnt touched them, should i be checking for leaks on the Factory BOV piping perhaps?
I know one thing it runs bloody beautiful and then you will be idling at the light and ...... tears and embarrasment lol
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979372
thanks for the help guys, but the idle is really loud and anooyin. like i put my intercooler on however didnt secure it casue my car just got out of an accident and didnt have my front bar ready yet. its a loud grunt and sounds like its chokin, not sure if engine was damaged in accident - though it phsyiccally seems fine but just hope that my bearing etc or somethin internally isnt affected and what sort of signs would this show??
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979499
maybe if some of these things you can't fix yourself and it becomes a little serious, it might be worth going to a real mechanic to have it checked out? Before the thing goes bang?... New engine vs taking it to the mechanic..? I know which one i'd be looking at if i couldn't solve it easily.
Edited by Poida
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979563
Have you even checked that there is oil in the engine and that it hasnt all leaked out or something?? If you havent got any coolant in the radiator I'd be checking this as well!
As per Poida's advice, getting a real mechanic to have a look at it would be the smartest option.
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-2979666
  • 8 months later...
have found the best way to check for air leaks (vacuum leaks) is to squirt brakecleaner around any possible leakage areas. If there is a leak the idle will rise slightly. Start with the obvious things like pipework and rubber boots etc, try the split line on the bottom of the plenum chamber, Skylines are known to leak here, also check the intercooler for leaks and all pipework joints.
To adjust the idle speed with the idle speed screw on the back of the plenum chamber you have to disconnect the Fast Idle Control Valve and the Idle Speed Control Valve and also the tps (good practice to check this fisrtly for <0.55 volts at fully closed. You can then set the base idle to around 750 rpm. Re connect everything and the ECU should hold the idle at 800 rpm.
However the most likely cause of your problem is a blow off valve venting to atmosphere. This is because the ECU acceses the amount of air inducted and sets the injector duty cycle accordingly to maintain the correct air/fuel ratio. Once the BOV dumps this air the mixture becomes overly rich until the BOV closes and rpm etc equalise. My R33GTS25t did the same thing. Once I plumbed the BOV vent back to the turbo inlet (AKA stock) it was fine again.
Finally the reason the Super FC doesn't use a map sensor is because Skylines don't have one, they just rely on the Mass Airflow Meter. This is also a common cause of many "Skyline Probs":wave:
https://www.sau.com.au/forums/topic/160444-idling-problems/#findComment-3533222
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
