Hi,
I think I've already arrived at an answer for this one, but I thought I'd double check that I'm not being too harsh on this car :cheers: . In the market for a skyline, had an RACQ inspection on a 1993 GTS-T, 102'000 km (offered for $13'000). I guess I'm interested to see if the condition report is out of the ordinary or not for a skyline of this age, I'm inclined to believe it's no good (advice from friends) - I'll ring the inspector to verify my decision, and check if a compression test had been done while I'm at it. Just painful thinking ahead to how many such checks I may need to go through before I get a clean bill of health, as they're reasonably expensive :happy: . Anyway report was as follows (in summary car was rated to be in reasonable condition, with some items requiring attention). Main concern is seepage from differential.
Defects requiring attention
- Oil seepage differential centre, rear of gearbox
- No evidence of rear steer operating
- Plug missing spare tyre well (and spare tyre not present)
Other items noted
- Fluid seepage rear of clutch master cylinder
- Oil seepage lower engine
- Oil seepage air conditioning compressor
- Surface rust left sill panel seam
- Left door lock surround loose
- Scuff marks lower section from bumper bar
- Bottom of left rear guard damaged, surface rust on same
- Surface rust noted under boot areas, heavy rust left rear inner sill panel
- Sill panels / floor frames dented
- Pads worn, monitor
- Sections of exhaust system corroding, front shields, muffler in particular
- Outer tie rod ends dust boots leaking grease
- Front struts dust boots broken/loose
Any feedback would be appreciated!
On a side note, can anyone recommend a Jap performance workshop that carries out pre-sale inspections?
Thanks,
Jade.
Edited by lee81
https://www.sau.com.au/forums/topic/160489-buying-a-1993-skyline-gts-t/
Sorry should have included that, it's an R33
Then thats easy, dont buy it :D
In all honesty it seems high price for a car that has some issues and it is the oldest of the r33's, i mean its the same age as my 32 ( I know which I'd have, haha :D ... you will never find a car that is perfect but its how many little issues you are prepared to accept. For that kind of money my mate got a mint R32 GTS-T but he did very well. I got my car a bit cheaper but its was stock as which i wanted and the paint was stone chipped etc cause the owner lived in the country, but i got a respray for $2k and got an exhaust, soon to get rims and suspension and with that I will have a car that I am very happy with. My main focus was a mechanically sound car.
To me it sounds like you need to see a few more and bring a friend, second opinions are always good. Best of luck
Edited by r32line
Thanks for the advice, that's 5/5 recommendations against (having asked friends).. damnit! :rofl:. So I'll have to look at some others, I might consider it if there's a significant drop in price, but otherwise I'll keep looking. Unforunately I'm keen on getting dark blue paintwork, and there's not nearly as many of those around as white/red/black models. I rang the inspector, he said while there is seepage he doesn't consider it a major issue to fix (causing long term drama), should just be a case of replacing the seals. Compression test had been done ('power balance' check as they list it), and results came out normal. His primary concern was rust, mostly surface rust, and one particular area around boot where it was getting a bit deep. I'm more concerned about engine condition, which he considers ok, seems it's more cosmetic issues with rust, suspects it has not been garaged (and that resale value will suffer if rust continues), as has more rust than a usual import.
Yeah like you said if it drops in price then you can consider it, but at $13,000 for a 93 model it would want to be better than it is.
The rust is a concern to me, on imports some of the cars in japan are driven in areas where it snows and they put salt on the road, this is bad news for the car as rust is a likely result. If it has already got rust arrears its not a good sign and a year later you could find it to be a lot worse.
So put all that to the seller and say at its current price it is not in your consideration, but you may consider it if its cheaper and u can spend money on it getting it all sweet.. Has it got any mods, or rims/kit/stereo? if not for $13k its quite pricey for what it is..... with the rust that is "getting a bit deep" and has your mechanic concerned then you really need to think if its worth considering at all. If so come up with a price that you would pay and be happy and then negotiate but do NOT go above that price.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
