Has Anyone Seen My Skyline
skyline_chick88
  • Replies 133
i own the car it is in my name. it is getting a surragant vin because it was a stolen and recovered car. they hadit becuase it had to go for an "inpection" on wednesday morning and when i went to pick it up, knowone knew where the car was. the owner was the one who sent it where ever it was and never told anyone about it.
grab lawyers and head down ! take these idiots to court would you pm me the company name so next time no one else i know will buy or get anything fixed from that mob !.. glad u found ur car !..
how can it be in your name if it hasn't had a roadworthy?
if it hasn't had that you can't transfer the car into your name, do you even understand how purchasing a car works?
i dont no. i didnt do that they did and yes it is in my name because my f**king plates are on it. i do now how it works but they have found away around it.
So glad to hear it has been found, I hope to see this car around now with you driving it and not somebody else. Also if you could PM the dealership that this all happened at it would be good. I just got my skyline so I wont be buying for awhile but it will be good to know for the future.
I hope you get to spend plenty of quality time with your car soon.
Just Ignore that twater GeeTeeAss, he just comes on to hear to cause trouble.....
i hope that everything goes well for you and that company gets what they deserve......
I sure you have the support of the skyline comunity behind you, please keep us upto date as what happends, and just ignore the wankers cos as you can see most of us are here to support you...
you always need a roadworthy when you buy a car, even if you buy it from a car yard. so either she is confusing a roadworthy with something else, or she doesn't have the car in her name. you can not transfer a registered car into your name without a roadworthy.
if they sold it to you unregistered you'd need to take the car to QT yourself to get it registered (or sign a form to say another person is authorised to do so), has any of this happened?
and phatboi, just because i'm not blowing smoke up her arse doesn't mean i'm not helping. she clearly doesn't understand how car purchases should work, and i'm explaining that.
maybe we should find out if she has a rego label wouldnt that tell you if its been registered or not and under what plate?
oh and can someone PM me the car yards etc details
Edited by Oblivion
i am not confused. I no what you have to do to register a car and transfer rego. I have NEVER seen a copy of the road worthy and the own of the yard said to me only 2 days ago that the company that does there roady worth's refused to do it because of the vin number issue. if you like i can post a copy of my rego cert. But i know for a fact that the car is in my name. i when and put the plates on myself. i personly went to QLd transport and did that a month after i bought the car. I wasnt in my name a few weeks after i bought it. But once i phoned the car yard it was transfer a day later.
if you have your rego details in front of you call up REVS or go to checkitout.com.au and run your VIN number
see if it is flagged as stolen, etc
hey sorry to hear about all your trouble. I'd appreciated if you could please pm me the car yards details as I have alot of contacts in that area (was working at import car yard till few weeks ago). Itll be interesting to see who it actually is as we delt with a few other yards.
Thanks
FOUND THE CAR!!!! IN SLACKS CREEK!!!! FROM WHAT I WAS TOLD THE CAR WAS BEING HIDEN THERE TILL THE OWNER GETS BACK FROM HOLIDAYS. nEXT PHONE CALL IS FAIR TRADING.
THANKS TO EVERYONE WHO HAS BEEN HELPING ME.
That sucked so hard! Awesome to hear that you got your skyline back. What F*#king dogs!!! can you pls pm me as well so I can avoid them pricks and let everyone I know to spread the word on how dodgy they are. Stoked you got it back.
Read a thread before you reply
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
