1. Got a set of JAP rims that i imported not long ago. They are in excellent condition as u can see from the pics. They are a metalic silver with polished rim. The measurements are:
18x9.5
+38
All round.
5/114.3
I have a set of close to brand new tyres (95%) which are 235/40/18 falkens and other 2 are some unknown brand. They will sit stretched on these rims which will look pretty nice.
Viewing available in S/E melb. Contact 0411462775 or [email protected]
Im after
$2000 with tyres or
$1700 w/out
Also open to offers and trades for other sets 18inch and above, send me a PM
2. GTR personal plates for VIC. Brand new never used. They read 'FRESH OFF THE BOAT GTR'.
PRICE: $250
Edited by FOBS15
https://www.sau.com.au/forums/topic/160509-jap-rims-18x95-51143-gtr-plates/
There nice rims, What brand are they? I doubt i'd pay that much for them even if they are jap spec.. Which im unsure about..
Ill take your word for it .. If only you lived in sydney..
Cheers, but i can bet my left nut that they are JAP wheels, i got them imported myself. Tell me if im wrong but u can tell straight away they r JAP. Just look at the style, similar to Work meisters and SSR's. Check out the other wheels i've brought in from JP and sold on and off this site.
If ur interested in these wheels make me an offer. Postage aint a prob. Also keen on sellin the Bronze NISMO LM-GT copies if u interested? 18x9.5 +30 Brand new in the box. Got different colors to chose from (approx 7+).
Edited by FOBS15
How much for the rims at the very bottom?
Im keen in starting up a group buy for the ones on the bottom photo.
They are NISMO LM-GT exact copies. Available in different colors pictured below.
Specs are:
>18 x 8.5 ET25 offset
>18 x 8.5 ET30 offset
>18 x 8.5 ET40 offset
>18 x 9.5 ET30 offset
Right now prices are $1650 with about 5 of us and after more ppl get in the group buys should c prices drop to about $1500 for a brand new set.
Tuff lookin wheels :wave:
Edited by Beer Baron
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
