Got two autometer guages here... oil & water temp. They're pretty small - 2" I guess. They are used, but in fine working order when removed not long ago. They come with light, cup & bracket.
Not sure what they're worth but $60 ono for each to kick things off i guess. Would also swap either for similar sized boost guage.
Guages in qld, but will post at buyers expense.
Cheers.
Edited by Mickroy
https://www.sau.com.au/forums/topic/160519-autometer-guages/
  • 3 weeks later...
being mechanical that means that their is the respective water and oil lines actually running into the back of the gauge ? or is it just two sets of wires one running to accesories power and the other to the sensors ? if they run to sensors then i would be very interested in them.
Thanks very much.
oil pressure runs a line, so mech. Water temp runs a wire... i guess water is elec then. They're both out of my gt starlet. The water temp one had an o-ring screwed to the side of the thermostat housing. I dont think there was a sender there. I will check. Either way it was a dodge install.
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
    • Been a long while since i have updated this money pit lol.  Have had a few tune related issues with the car, first blowing the frost plug out the back of the head and then blowing the headgasket 3 months later, which has now been retuned and sorted. Done a few little changes along the way as well, i wasn't happy with the wheel and brake setup, so start of last year i managed to get myself a set of r35 brakes and nismo lmgt4 18x10.5 +15 Upgraded to now running a Precision Gen 2 6870 with a 1.15ar, to be honest felt more like a downgrade as the car feels much lazier around town compared to the Gen2 6466 previously. 0761719E-5683-43F7-BD3B-4BD94335DFF4.mov
    • Hi there, i am currently using the Elmers Racing Billet merge collector, we are using sch40 tubing and 1.5" ID, no cracks so far. however if i was to do it again, i would go sch10 with 1.25" runners
    • I haven't touched the turbos so might need to look at that 👍 Appreciated 🙏
    • If you haven't replaced the OEM turbos, replace them sooner than later. I have seen recent pictures of what OEM ceramic turbo failure can do in an RB26 and it will make a 10k AUD budget look like a joke. Single vs twins have been done to death on this forum. If your turbos haven't fallen apart you can probably send yours off to Hypergear for rebuild. The journal bearing option will have more turbo lag but it's a good bit cheaper. I would probably go for ball bearing CHRA but keep in mind ball bearing turbos are more particular about oil pressure/flow.
