from the research I have done it seems pretty uncommon to damage the engine when an exaust turbine drops off.
sure if your doing 200ks and on the redline + engine cough it could make its way through all the piping and into the engine.... but it'd be pretty rare I'm tipping.
reason why I am waiting is because when a terb blows I'll be doing the entire head and manifold system and putting it on my stock bottom end until its blows >_<
if you want to speak to someone who had to rebuild due to a turbo failure, pm Duncan. his turbo actually sucked up a washer which chopped and damaged his bored etc. its unlikely that you would need a rebuild after an exhaust wheel failure. a compressor wheel failure is a complete different story. you'd just need to hope the fins in your fmic caught everything.
take your intercooler and hoses off and see if there is any scratching in them. that would be an indicator to whether or not it was compressor failure.
I wouldn't wait if I was you, you're playing with death. That was my attitude... but the thought that potentially my engine is now rooted due to ceramic shards is a bad feeling. But I'm also a tad excited about the forced upgrade - if that turns out to be required.
To those mechanics out there who have seen many blown up gtrs - what percentage of them would you say have done an engine as a result of the turbo? I know it happens - but is it rare?
Very common....Supras too
After you noticed it did you back off straight away, or were you still accelerating? If backed off straight away (no good).
I have a feeling your engine is fine. I think all the noise your hearing is the comp wheel hitting against the cover.
Well the chases are if you have older stock or upgraded turbos and they are getting some Km's on them there is every chance that a wheel/bearing has failed in the turbo.
I have had my engine completly destroyed and a mate of mine has had the same thing on a 20,000 km old R34 vspec. This happens all to easy and a bit of extra boost then the wheel falls of....... then shit happens :ermm:
I had after market steel wheel turbos and the bearing let go which then wheel hit the housing and it was all over in a cold of smoke...!
The turbo then enters back through the to the head and bore through the velocity of the wheel and the shattering particals then following the curve of the housing and manifold through to the head.
It does not seam to make much difference on the throttle postion reving the car up or down, it is rpm of the wheel and the volcity of the bits.
If comp test ok.... some new snails and off you go... :sorcerer:
We've started dismantling the whole setup, and as you'd expect in the world most cramped engine bay, everything is a pain in the arse.
Firstly, yes I found the exhaust wheel sitting right where you'd expect it in front of the cat. See photos. The majority of the actual blades seem to have disintegrated, where I don't know yet - hopefully straight through the cat and out the exhaust pipe.
Next we started pulling the intake pipes off only to discover a hell of a lot of oil lining the pipes along with a substantial amount of mud!!! Well fine dust embedded in the oil. That's not good. See pic.
Once all the piping was off we discovered the oil and water lines. Shouldn't be too hard to get that out of the way - WRONG! The bolts for the water lines will not move - they just won't. Firstly the nut seems a wired size, but after much stuffing around found a spanner that was a pretty good fit. No matter how much muscle was put in, it wouldn't budge. Even a dirty great big pipe on the end of the spanner wouldn't do. See pic with red circle for what I'm talking about. The only way forward is to completely bugger something, or for someone to produce some exotic tool to get it off... and that's just the first one of about five, they're all tight as hell.. and I don't see how you'd get the ones going into the turbo off, they are at such a bad angle to get a spanner on.
I'm sure plenty of people have faced this situation while getting at gtr turbos - anyone care to share some wisdom?
Edited by cash0
The best way to get that line off is with a decent PIPE spanner. Snap-on make the best pipe spanners as they dont spread open and round the bolt/nut head. You can interlock the pipe spanner with another ring spanner for extra length and torque. Thats not the wors't of it yet mate, plenty more instal for you my friend... enjoy!
^^ Do you have a pic of this pipe spanner??? I am helping cash0 with this...
Another thing to think about cash0 is:
Will any of this water piping be needed with your replacment turbos. Ie, are you going to have to run braded oil and water lines anyway, like if you went for a big single. If thats the case we dont have to worrie about damaging them too much...
SK suggested having a sticky beak inside the zaust mainfold as thats the path that the ceramic would go towards your values and through to your cylinders. I think this is the safest thing to do before we turn it over again.
Ps, just spoke to will. He saw you on the side of mugga when it happened :P
Ps, just spoke to will. He saw you on the side of mugga when it happened :)
Certainly. This is a pic of a snap-on pipe spanner, disigned for such situations as this. Here is another pic of how to interlock thy pipe spanner. :sorcerer:
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
