Hey anyone made a custom AFM??
Am thinking of using a Q45 (90mm 3.5") internals and plumbing it into a 4"pipe.
The reason you might say, to slow the air speed through the meter which will give a greater scope. Undoubtly 4" is not much of an increase, but i can also bolt it straight to the 4" turbo inlet and use a 4" filter. I was maxed out at 20psi (260rwkw) so maybe this may help a little.
Plus it is custom and i like tinkering. hehehe
https://www.sau.com.au/forums/topic/160559-custom-afm/
your telling me you maxed out a q45 afm at 20psi and only made 260rwkw that doesnt sound right.. more info please
Ah good question.
Had low comp pistons and rb25 head, =extra low comp setup. It was somwhere around the low 7's cr.
When you think about it, 20psi is great for an AFM on rb30 setup, but it was the comp that was killing me, saying that it was an ignition monster, just wanted more and more. Could've thrown 30psi in there and it would've been happy.
However i have high comp standard rb30 pistons in there now so comp is a little more respectful, though would love to make over 300rwkw. So we just see.
Mate its a good experiment just to see how it all goes. plus "Custom" love custom!!!
https://www.sau.com.au/forums/topic/160559-custom-afm/#findComment-2983997
My understanding is that if you change the internal diameter of the pipe in which the air flow meter resides you change the calibration of the meter.
https://www.sau.com.au/forums/topic/160559-custom-afm/#findComment-2984524
thats more than likely trua and something that has already been discussed in the Forced induction section.
the modifictaion to the AFM would require you to create a boxed section one the side of the inlet pipe and im assuming that it would require it to be on a straight section too to ensure the flow is even through the meter.
be some fiddly work to get the mounting threads welded on to keep the unit flat inside your box.
https://www.sau.com.au/forums/topic/160559-custom-afm/#findComment-2984602
Yah calibrated, true, but basically whats the difference in calibration when you tune the car for the new calibration?? Yah am running a Power FC, so its all good. The only time you'd be worried about "calibration" so to speak is when you are using the standard comp.
Basically this way you are kinda tricking (real lamens terms) the computer there is less air going through the AFM, the just adjust the mixtures to suit, not rocket science.
Yah tricky making a box?? well really all you need to do is to get a bit of pipe, machine or file a basic flat, make a base plate, weld that on, then by cutting some ally plate say 20mmhigh x what ever the standard width is, then just weld it all up. Screw the AFM unit in and just silicon on a top if you can't be bothered tapping and screwing the top.
Piece of piss(if your a welder/fabricator)
Was thinking of it last night in bed for about an hour. Should hopefully have started it and maybe some pics by monday.
https://www.sau.com.au/forums/topic/160559-custom-afm/#findComment-2985319
only reason if that would be tricky is if the underside of the circuit board isnt flat
https://www.sau.com.au/forums/topic/160559-custom-afm/#findComment-2985336
  • 2 months later...
Might be a bit of science in it, the afm reads the airflow and outputs in a logarithmic curve, then the computer outputs that in a linear curve using a conversion table, by increasing the diameter you may throw the curve well out of whack. How's it all going anyway? im curious to know
https://www.sau.com.au/forums/topic/160559-custom-afm/#findComment-3135213
  • 3 weeks later...
  • 3 weeks later...
Hi, I don't know much about air flow meters but i need one for my 95 series 2 gtst skyline.
Can anyone advise me on what one to get and where to get it from?
Cheers.
You will get a better response in the Forced Induction section.
stick with STD or if you have a Power FC and are chasing power try a Z32..
Search in FI if you are unsure about this
https://www.sau.com.au/forums/topic/160559-custom-afm/#findComment-3203032
  • 1 month later...
    • Don't they cool down technically when you're sitting at a set of lights?
    • The circuit if not a resistor divider is using an opamp to deliver a specific current normally. By maintaining the current as resistance changes, the voltage does too. Add to that, thermistors are normally non linear too,which can make creating a function impossible. Most uses of a thermistor people will utilise a lookup table to get the corresponding temperature.
    • On a scale of 1 to 10, how shit are the RE003's? (10 being ultra mega shit) Was hoping they'd be alright for a non-daily driven R32 that might get driven to Charnwood Macca's in the dry once a month, and maybe the odd hoon up and down the hills that pass for mountains in sunny Canberra.  Bob Jane currently running a "Buy 4 Get 1 Free" deal on RE003s and my brain can't comprehend anything else being value for money
    • Yeah, they look good. I should try to fit them on mine. But being a GTSt, the guard shape probably doesn't suit properly.
    • Nah, it's not a simple voltage divider. I'm not enough of an electronics guru to know how they make these circuits work. If I had a better idea of how the ECU's temperature measuring is done, I could then actually do as you want, which is turn that resistance chart into a voltage chart. But my approach has not worked. What I did was interpolate the sensor ohms values for the temperatures you listed, as you did not have any of them on a temperature ending in zero or 5. These are: °C ECU V sensor ohms (interpolated) 58 2.68 11.85 57 2.7 11.89 56 2.74 11.93 54 2.8 12.01 49 3.06 12.208 47 3.18 12.284 43 3.37 12.42 I then assumed 5V supply to the resister and calculated the voltage drop across the sensor for each of those, which is just 5 - the above voltages, and then calculated the current that must be flowing through the sensor. So you get:             Values in sensor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current 58 2.68 11.85     5 2.32 0.195781 57 2.7 11.89     5 2.3 0.19344 56 2.74 11.93     5 2.26 0.189438 54 2.8 12.01     5 2.2 0.183181 49 3.06 12.208     5 1.94 0.158912 47 3.18 12.284     5 1.82 0.14816 43 3.37 12.42     5 1.63 0.13124 And then use that current and the ECU's sensed voltage (which must be the voltage drop across the in ECU resister is there is one) to calculate the resistance of that in ECU resistor. You get:             Values in sensor   Other resistor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current   Volt Drop Resistance 58 2.68 11.85     5 2.32 0.195781   2.68 13.68879 57 2.7 11.89     5 2.3 0.19344   2.7 13.95783 56 2.74 11.93     5 2.26 0.189438   2.74 14.46381 54 2.8 12.01     5 2.2 0.183181   2.8 15.28545 49 3.06 12.208     5 1.94 0.158912   3.06 19.25592 47 3.18 12.284     5 1.82 0.14816   3.18 21.46325 43 3.37 12.42     5 1.63 0.13124   3.37 25.67816 And that's where it falls apart, because the resulting resistance would need to be the same for all of those temperatures, and it is not. So clearly the physical model is not correct. Anyway, you or someone else can use that information to go forward if someone has a better physical model. I can also show you how to interpolate for temperatures between those in the resistance chart. It's not fun because you've got to either do it like I did it for every 5°C range separately, or check to see if the slope remains constant over a wide range, then you can just work up a single formula. I'm just showing how to do it for a single 5° span. For the 58°C temperature, resistance = 11.77+2*(11.97-11.77)/5 The calc is a little arse backwards because the resistance is NTC (negative temperature coefficient), so the slope is negative, but I'm lazy, so I just treated 58 as if it was 2 degrees away from 60, not 3 degrees away from 55, and so on.
