hey guys im in the process of doing the boost mod thats in the diy section and i have a problem. i decided to run the wire into the cabin and mount a switch on the dash. pretty simple you might think but then again so am i :( . i got the switch from supercheap and its one of those that has a little led that lights when its on. its got 3 pins on the back of it and has this diagram on the back
i cant seem to get the led working when the switch is closed (or at all). i have no idea about electrics/electronics and im now very confused. my understanding is that i run the wire that was spliced into the black solenoid wire to the 'supply' terminal, and then a wire from the 'load' terminal to the closest earth point. i dont understand what to do with the 'led/earth' terminal though. how does it fit in? somebody help!
btw where is the best earth, nearest to the dash on the right of the steering wheel
https://www.sau.com.au/forums/topic/160591-help-re-stock-hi-boost-mod/
I'd imagine that the "supply" for a switch originally would have had positive power going to it, so that when you close the circuit (switch "on"), the middle leg would output power to your device (coupled with the "earth" that is constantly grounded for the LED).
With the grounding mod, you're not running any positive power to the switch, you're just using it to break/complete the grounding... as the stock ECU grounds the solanoid wire to run 7psi over 4500rpm.
So... as it is now, you'd use LOAD to the chassis, and SUPPLY from the actuator/solanoid (or vice-versa, doesn't matter). Close the circuit, solanoid sees ground... runs 7psi.
I don't think you'd want to use the EARTH leg, cause it runs through the LED... i'm not sure whether it would allow anything through? Diodes are a one-way deal but i'm not sure how that would work with passing a ground through the LED and out to the SUPPLY. Who knows? Someone does! I believe the EARTH is purely for the LED to illuminate when positive power is put to the SUPPLY side, and as the power comes out to the LOAD for whatever you're turning on, the power also goes to the LED, which has its own ground. You have no positive power, so it won't light up.
I'm quite tired, but... if the LED was reversed, you could possibly run power to the EARTH side, and use the LOAD to go out to the actuator, and then use SUPPLY for a ground to chassis.
That would allow the LED to illuminate when you give the switch some ground (turn switch "on"), while giving ground to the actuator.
It would also light up when you had it "off" and went over 4500rpm, as the LED will see ground from the actuator when the ECU gives it some.
I *think*.... but you'd have to swap the led around, cause as I said... diode... one-way.
lol. if im awake the rest of y'all should be too. ;)
thanks alot randy. that was really bugging me. i think that i will have it the way you said with the led lighting up. now i just gotta figure out how to flip the led. much appreciated man :(
load and earth go straight to chassis, this means the nearest bolt on a metal part of the car.
supply comes from the wire in the solenoid plug. perhaps you cut the wrong wire. trial it both ways. do not unplug this plug, just cut one wire on the solennoid side of the plug. if you leave the car loom alone you can always buy a new part if you want to sell it unboosted and wont get confused if something goes wrong.
did like you said randy. took the switch apart and flipped the led. it worked well. i took power from the ciggie lighter cos theres 2 many wires under the dash and i dont want to f*k anything up.
anyhoo, now i just gotta epoxy the switch into the coinholder and i can put it all together. i'll post pics wen finished.
thanks again guys
btw jeffworld: i did have the right wire. it was just the switch that was the problem. and bout ur other point, that was my plan anyway. hence y i went to the trouble of modifying my coin holder rather than drilling holes in my dash. that way its just a clip in/out affair. thanks 4 the help though dude. much appreciated
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
