Hi all,
Well I have to put in my two cents worth on this one!! I went to Skipper Mitsubishi on Sunday and saw a NON turbo, NON aero top white supra, standard spoiler kit. I asked the salesman how much and he said $45,000!!! I could not beleive it! he had also told me friend the same figure! Through personal imports auctions i see cars like this going for $22,000 on sites such as prestige motor sport www.prestigemotorsport.com.au
Anyway it was a 96 model car so i will give them credit that it is a kinda newer model, HOWEVER when i opened up the somewhat tiny boot i was astonished to see the boot with water EVERYWHERE! i questioned him about it and he said "oh we had it steamed cleaned" i shook my head in disbeleif!
I am not one to put a car company down as they have to make money and unlike personal importers they have warranties on their cars, however whay is this car going for $45,000? i would rather an R33 GTR from c-red!
https://www.sau.com.au/forums/topic/1606-how-can-this-be/
absolute rip off!!
I really think the main reasons behind that price are;
a) Southside Mitsubishi would have no idea about a Toyota Supra, especially considering it is not aus spec.
B) They are jumping on the import bandwagon and want to rip off any potential boy racer who wants the 'look' of a Supra.
https://www.sau.com.au/forums/topic/1606-how-can-this-be/#findComment-31066
Found out for myself when I was looking for Skyline how much of a rip off this pricks are. For the same car (speaking in condtion, Km,etc) these guys charge about $5000 to $10000 more. And none of the cars their had the "goodies" that other yards had.....
just my observation
Dan
https://www.sau.com.au/forums/topic/1606-how-can-this-be/#findComment-31532
Guest HeffR33
Skippers are a rip off.
I was at Skippers Imports about 3 months ago having a look.
They had a 95 GTST with 60 on the clock. The only mods from standard were a set of 18inch volks.
They were asking 31g's. When I asked the guy why so much, he got really defensive and told me that they did a heap of work to the car, then proceeded to tell me all the work that they do to their cars......which was standard compliance work.
He asked me if I was looking for a Skyline and I told him that I had just imported my own. He then walked off rather sheepishly.
I would suggest never buying from these rip off merchants.
Heff
https://www.sau.com.au/forums/topic/1606-how-can-this-be/#findComment-32534
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
