So in my quest to find my cold start issues with the car, as described here
http://www.skylinesaustralia.com/forums/in...howtopic=160180
I did the following test.
I put a fuel pressure gauge in and tested the fuel leakage and so forth.
Basically if left alone the fuel pressure eventually bleeds off to 14.5 psi, over the night, which is to spec, I need to find the correct page again to give details. So then I pressurized the system and blocked off supply and return. The reading was 40psi, after and hour still 40 psi, after 2 hours 39 psi, but this was at night 11:30pm to be exact. Then over night the pressure dropped of to 20psi or so.
However I was told that the pressure loss is worked out over 30 minutes, so if there is no substantial pressure loss the system is ok. THIS IS TAKEN FORM A MECHANIC THAT WORKS ON FUEL DELIVERY SYSTEMS. CAN SOMONE CONFIRM.
Does this mean the injectros are leaking badly? or something?
https://www.sau.com.au/forums/topic/160605-testing-for-a-leaking-fuel-injector/
If it's worked out over a half an hour period, and from one point to the next, which is an hour apart, the reading is fine, since 40PSi at A is equal to 40PSi at B.
That would be my thoughts.
Wouldn't it work for you to unplug the injectors out of the motor, pull the whole fuel rail out, have injectors plugged into the fuel rail and into the loom, sitting it over a bucket, prime the fuel system up, and just leave them to sit and see if you have petrol in the bucket at the end? (I'd also put a rag over the top of the injectors and bucket to help avoid the fuel from evaporating.
A mate of mine used to have a spare manifold where he would sit it on top of a piece of paper.
The reason for the manifold is that the injectors will not sit in the rail when pressurised, they require the manifold to be held in.
He ran a long piece of hose from the car to the manifold/fuel rail/injectors sitting on the ground, pressurised it all up and then let it sit overnight. Check the paper in the morning and its obvious if any fuel has dribbled out the injectors.
His would hold pressure fine as yours do but overnight we could see fuel had leaked from the injector. Unsure if this is normal, we assumed not.
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
