So in my quest to find my cold start issues with the car, as described here
http://www.skylinesaustralia.com/forums/in...howtopic=160180
I did the following test.
I put a fuel pressure gauge in and tested the fuel leakage and so forth.
Basically if left alone the fuel pressure eventually bleeds off to 14.5 psi, over the night, which is to spec, I need to find the correct page again to give details. So then I pressurized the system and blocked off supply and return. The reading was 40psi, after and hour still 40 psi, after 2 hours 39 psi, but this was at night 11:30pm to be exact. Then over night the pressure dropped of to 20psi or so.
However I was told that the pressure loss is worked out over 30 minutes, so if there is no substantial pressure loss the system is ok. THIS IS TAKEN FORM A MECHANIC THAT WORKS ON FUEL DELIVERY SYSTEMS. CAN SOMONE CONFIRM.
Does this mean the injectros are leaking badly? or something?
https://www.sau.com.au/forums/topic/160605-testing-for-a-leaking-fuel-injector/
If it's worked out over a half an hour period, and from one point to the next, which is an hour apart, the reading is fine, since 40PSi at A is equal to 40PSi at B.
That would be my thoughts.
Wouldn't it work for you to unplug the injectors out of the motor, pull the whole fuel rail out, have injectors plugged into the fuel rail and into the loom, sitting it over a bucket, prime the fuel system up, and just leave them to sit and see if you have petrol in the bucket at the end? (I'd also put a rag over the top of the injectors and bucket to help avoid the fuel from evaporating.
A mate of mine used to have a spare manifold where he would sit it on top of a piece of paper.
The reason for the manifold is that the injectors will not sit in the rail when pressurised, they require the manifold to be held in.
He ran a long piece of hose from the car to the manifold/fuel rail/injectors sitting on the ground, pressurised it all up and then let it sit overnight. Check the paper in the morning and its obvious if any fuel has dribbled out the injectors.
His would hold pressure fine as yours do but overnight we could see fuel had leaked from the injector. Unsure if this is normal, we assumed not.
    • Looking for a S2 front grill for an R34 GT/GTT Doesn’t have to be in excellent condition as I’m looking to paint it. Would preferred if the clips were around.    The $500 this marketplace guy is asking sounds ridiculous in my opinion.
    • Nah, just take the other one off too
    • A mini mini-gun.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
