Gb#2: Jun Spec Crank Collar & Oil Restrictors (x2)
  • Replies 47
First attempt at a table;
-------------------- -------------------- RB26 -------------------- -------------------- RB25/20 -------------------- -------------------- -------------------- RB25
-------------------- -------------------- No VVT -------------------- -------------------- No VVT -------------------- -------------------- -------------------- VVT
-------------------- -------------------- Front Feed, Rear Feed -------------------- Front Feed, Rear Feed -------------------- VVT Supply, Front Feed, Rear Feed
Standard Oil Pump
Road ----------------------------------- 1.5 mm, Block off, ------------------------------ 1.5 mm, Block off, ------------------------------ Leave, Block off, 1.5 mm,
Drag ----------------------------------- 1.25 mm, Block off, ------------------------------ 1.5 mm, Block off, ------------------------------ Leave, Block off, 1.5 mm,
Circuit/Drift ------------------------------ 1.25 mm, Block off, ------------------------------ 1.25 mm, Block off, ------------------------------ Leave, Block off, 1.25 mm,
RB26 N1 Oil Pump
Circuit/Drift ------------------------------ 1 mm, Block off, ------------------------------ 1 mm, Block off, ------------------------------ Leave, Block off, 1 mm,
Aftermarket Oil Pump (Jun HKS Apexi Trust etc)
Road ----------------------------------- 1.25 mm, Block off, ------------------------------ 1.5 mm, Block off, ------------------------------ Leave, Block off, 1.5 mm,
Drag ----------------------------------- 1 mm, Block off, ------------------------------ 1.25 mm, Block off, ------------------------------ Leave, Block off, 1.25 mm,
Note that all of the above assumes;
1. Standard Nissan clearances
2. Oil cooler (where necessary)
3. Improved oil control in the sump (where necessary) including wings, baffles, one way doors etc
4. External oil return from cylinder head to sump on all circuit/drift cars and drag cars with non standard oil pumps
5. Hydraulic followers in RB20/25's. if changed to solid followers then use RB26 restrictor as above
6. Castrol Edge 10W60 (or equivalent)\
7. Improved oil flow in the cylinder head return galleries through the block.
8. Refer previous posts in this thread
;) cheers :laugh:
PS; This guide is for what ever cylinder head you use, the block is irrelevant. Whether you use an RB20/23/24/25/26/27/28/30 bottom end is doesn't matter when it comes to restrictor sizes. It's all about what oil pump you use, what cylinder head and what you use the car for.
Here a table from Sydneykid for picking what restrictors u need ,
Pm sent as well
Thanks bud... I purely went off what Matt said; but with this table I think everyone will be able to see for themselves what is required.
sky30; status updated...
I will call Matt sometime today and ask if he can do the cheaper price for the 4 sets already paid for... this will move things along faster.
I called for Matt yesterday afternoon but he was off sick; have left a message for a call-back today and it should be all good!
Update; all the crank collars have been paid for and will be sent out (to me) by the end of the week; I'll ship them all off as soon as they arrive. FYI Matt from NZ is an awesome guy to deal with; honest and to the point - so if you need anything from NZ; go through him >_<
  • 3 weeks later...
Hey all,
As far as I was told, Matt had sent them off yesterday. They had to get the 1mm restrictors machined up as they had run out at their shop.
Thanks
Stan
  • 3 weeks later...
hey im very interested cos i will be needing thse for my rb25/30 combo, just wondering if this buy is still going and if you could pm me the payment details. im after one crank collar and 2 restricotrs at 1.5mm possibly 1.2mm will get back to you on that one
Just received a call from DHL; the collars have been sitting in a holding facility for the last week! Apparently (truth level of this unknown) the address was listed as 39 and not 59!!! How bloody nice of them to call me after a week~
Anyways, just letting you all know that they will arrive tomorrow and I will be shipping them out to you on Friday :cheers: Happy Times!
received mine today, thanks stan. Looks good, but no grub screw(or hole)? I understand its not essential, just for safety, btw do you know how much interference fit these are supposed to have?
Hey Adrian;
The grub screw should be in the packet; I personally checked all of them before sending out :rofl: it's a tiny little black thing - perhaps check that it didn't fall out into the tough bag?
Also; there's no hole in the collar because the grub screw is really an "optional" item that not all places choose to use. As such; no pre-machined hole is drilled for it. This is what I've been told by Matt any ways...
Thanks
S
hey thanx stan every thing turned up undamaged and very well paked i may add had all the coerrect size parts and grub screw so thanx alot ay this was a great but that saved me a few dollars. thanx again
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
