hows it going skyliners.
started my car just a few min ago to realise i didnt have any more cold air feeding into my car, which might be because ive ran out of the A/C gas. i cant remember to well but there was a thred about this real cold A/C gas somewhere in VIC.
would anyone know where to get this stuff from?
and how much would we be lookn at?
https://www.sau.com.au/forums/topic/160618-ac-gas/
No A/C re-gassing is going to be any colder than another guys gas... thats just silly!
It must be installed by a A/C dude however.
Should be around $70-$100 for a regas, doesnt really matter where you go.
450 results:
http://www.yellowpages.com.au/search/postC...c&stateId=2
https://www.sau.com.au/forums/topic/160618-ac-gas/#findComment-2983004
450 results:
i was informed there are certain gases which are colder then others....ur saying this is false?
https://www.sau.com.au/forums/topic/160618-ac-gas/#findComment-2983494
I think what he means is... the normal or the stock gas everyone is ment to put in or regass it with shouldnt vary in temperature it should have the same chemicals and what not. AC Gas should not vary. Well thats my opinion.
https://www.sau.com.au/forums/topic/160618-ac-gas/#findComment-2983870
Ehrmmmm yeh, if u just get it regassed with the normal stuff (?!?!) it'll be alot colder, they die after a while, check that your vents are opening fully to, my motor was getting caught up and i was only getting half of the a/c air into the car
haha sounds like the blend door servo motor dead. I have this same problem, manually set the flap onto full cold and dont touch the temp controls :ermm:
Someday ill buy a working motor..someday...
https://www.sau.com.au/forums/topic/160618-ac-gas/#findComment-2985611
the only gas in australia allowed for a/c in cars is r134a which is ozone freindly
no its quiet possible that you car had r12 in it which actually has a lower chill point.
so yes in theory there are colder a/c gasses. but no one is allowed to use r12 because it damages the ozone.
newer cars from around 1992 are r134 type systems. also you cant pop r12 into a r134 system as if there is resident r134 the two gases mix and cause major corrosion internally.i would take it to a auto elec who has experienced knowledge of a/c .ie knows the difference between out of gas and fooked a/c system parts.
you may well have a blend door motor issue . as they dont have a heater tap to turn off water to the heater core.
go and get it checked by a professional
my two cents.
https://www.sau.com.au/forums/topic/160618-ac-gas/#findComment-2985881
    • Not sure if this helps but I had a similar issue where one of the doors wouldn't lock unless I pressed the lock key twice. Turns out the door actuators were f**ked. In the Nissan service book it says to lube it every now and again, I guess put a bit a bit of wd-40. I replaced mine and haven't had a problem since.
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
